Cup 1 17" Italian replica wheels on a 928??
hello all,
need some help and advice for a friend who has a 928.
He wants to put 17" Cup 1 wheels on the car (Italian replica's I think) they are 7.5J and 9J and I think off-set is 55 will they fit??
All help greatly appreciaited
They will fit.
For later cars (86.5 onwards) the offset is the minimum generally regarded as acceptable - and will eliminate the negative scrub radius of the later suspension (10mm from memory)- higher offset would be ideal. I have ET55 fronts on one of my S4's and they're noticeably less stable than the correct ET65 fronts I have on another S4.
Early cars have a little more leeway on offset as they have a higher negative scrub radius (16mm from memory) than the S4-style control arms - so on them ET55 still provides some negative scrub radius.
Either way they'll fit, altho' depending on what rubber he puts on the front, they may rub at full lock.
Been selling Twinkies on Ebay,
have some extra cash right now.
I am running those. Had to roll the inner lip front fenders a bit so the outside shoulders wouldn't rub in the turns, and the inside shoulders rub the chassis a bit at full lock. In other words... perfect fit. Running 225/45/17's.
Captain Obvious
Super User
Super User
