Trans fill 17mm or 18mm hex bolt...
I need to check my trans oil level due to a very small leak (approx one drip a week, and want to be safe).
I did search but looks like a little conflicting info on the hex bolt size as to whether or not it is a 17mm or 18mm. Can anyone confirm which it is before I crawl under there with a set of dial calipers? I'll need to order the correct tool or make one with a bolt and want to buy the correct size and avoid multiple purchases.
1984 US model, 5 spd, LSD. Thanks.
Anyone know whether it's the same size in a '91GT. I think I saw a thread at one point that indicated they were smaller in the later models but I can't find that thread again.
Archive Gatekeeper
Should be 10mm hex on a '91 GT.
Archive Gatekeeper
Or you can double-nut a short-ish M10 bolt (steal one of the bolts that holds the front LCA bracket to the frame rails) and stick its 17mm head into the plug, then use a 17mm wrench on the inner nut to turn it out.
Kroil the hell out of the plug first, you don't want to strip it. And loosen the upper fill plug first.
Craic Head
And when you put it back on, use a torque wrench. The tendency with these seems to be to put some ungodly amount of torque on there because of the size of the wrench it uses. I think that's why they went to 10mm in the later years. It just has to be tight enough to keep from backing out, it's not holding the axles in or anything.
22nm = 16.22 ft/lbs. That's almost what you get with one finger on a 1/2" drive, which is usually the only thing that has a 17mm allen head socket.
Thanks for everyone's help. I'll make sure I get a 10mm hex head and a torque wrench in my box before getting my car on the lift.
