928 Forum 1978-1995
Sponsored by: 928 Specialists
1980 928 dash instrument problem
Old Oct 18, 2010 | 01:59 AM
TOPEND's Avatar
TOPEND
Default 1980 928 dash instrument problem
Hi all,
I have been reading the forum over the past few days and searched and tried most things i have found info on.
I have a problem with the dash, the car was restored and now that i have installed the dash back into the car the instruments are giving me problems.
When i put the ignition on reds the fuel pressure goes up all the way, then when i start the car it stays the same, tacho still on zero, battery volts on zero, fuel level on zero and water temp on zero, but when i put the handbrake down the fuel level and the water temp go all the way up, battery volts still at zero and tacho still at zero. I located the handbrake wire and no shorts to the handbrake wire?
Dont know what to do???? any advice will be much appreciated.
Regards
Dave
Old Oct 18, 2010 | 04:33 AM
Leon Speed's Avatar
Leon Speed
Hello Dave and welcome,
Lot's of possibilities here, of which the easiest are: fuses, dash connectors and/or grounds.
More info would be helpful: what MY is your 928 and was restored?
Old Oct 18, 2010 | 07:45 AM
TOPEND's Avatar
TOPEND
it is a 1980 928, car has been resprayed , and the interior has been retrimmed. I just ordered a new printed circuit board as the old one was okay but i thought while its out ill replace the 30year old unit, also i took to instrument cluster to get inspected, just hope i can sort this mess out.
Old Oct 18, 2010 | 11:39 PM
TOPEND's Avatar
TOPEND
bump
Old Oct 19, 2010 | 08:26 AM
Leon Speed's Avatar
Leon Speed
It's not the instrument cluster. If I I were you I would:
- take out the old fuses, clean all fuse contacts thoroughly, put in all new fuses
- clean the dash connectors with a pencil eraser
- clean the grounds beneath/behind the pod and the grounds above fuse panel
Try it with the old circuit board and keep the new one as a spare. If that doesn't work, replace the circuit board with the new one.
Old Oct 27, 2010 | 09:44 PM
TOPEND's Avatar
TOPEND
new circuit board hasn't fixed the problem, had to change it anyways as the old one was just worn out.
not sure where to locate these grounds behind the pod or on the pod or near the fuse box. (cleaned all the fuse holders) and now waiting on some new fuses.
Also found under the dash the central module box, out of one of the plugs there is one wire(brown with red stripe) that is out of the plug, could this be the problem? only thing is i don't know where i need to put it as there a five empty places to put it in
any help will be appreciated
regards
David
Old Oct 28, 2010 | 05:25 PM
Tom928's Avatar
Tom928
Default Don't use a pencil eraser
Originally Posted by Aryan
- clean the dash connectors with pencil eraser
I would discourage the use of pencil erasers for cleaning electrical contacts.
Some big players in industry have found;
The eraser is desctructive (removes metal), leaves a residue (film on the metal) and contamination (small particulate stuck to the metal).
It also leaves the surface uneven due to uneven pressure which can cause intermittant contacts where vibration is a factor.
I use to use this method for years until one day I see the metal beginning to disappear from under the eraser.
I did some checking and found it is no longer a recommended practice.
Use a chemical cleaner.
Don't use isopropyl alcohol. It leaves a thin film that inhibits conduction.
A product called DeoxIT (No affiliation) is good and supported by the industry.
http://www.deoxit.com/
They have several application methods; however, the squeeze tube is very easy to use with a soft cloth and is only $6.95.
Cheers,
Old Oct 28, 2010 | 05:32 PM
soontobered84's Avatar
soontobered84
Are you sure you got the plugs at the back of the pod in their correct places? The right one and the center one are really easy to accidently swap.
Old Oct 29, 2010 | 01:47 AM
TOPEND's Avatar
TOPEND
ill have a look and update.
Im still trying to figure out why the wire under the dash that goes to the central module is out of the plug( brown wire with red stripe)
cheers
dave
Old Nov 1, 2010 | 09:22 PM
TOPEND's Avatar
TOPEND
got it fixed finally,
now just cant get illumination lights to work with the headlights.
Old Nov 1, 2010 | 09:36 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
Have you checked the little round dial under the instrument pod? The one that controls the instrument dimming?
Old Nov 2, 2010 | 12:30 AM
TOPEND's Avatar
TOPEND
yeah checked the dimmer, still not working. I changed the 3 bulbs on the back of the cluster even though the ones already in there work when i put 12v through them.... now with the 3 new bulbs i get the middle illumination light working only?? and this is on ignition only
Old Nov 2, 2010 | 12:31 AM
Landseer's Avatar
Landseer
Try bypassing the dimmer
Old Nov 2, 2010 | 09:55 AM
tlsmith1999's Avatar
tlsmith1999
What did you do to get it to work?
Old Nov 2, 2010 | 03:31 PM
vanster's Avatar
vanster
I have a similar issue. My indicator lights work but the dash lights don't work
I am thinking it may be the dimmer switch. Is the dimmer switch a weak link within the dash electronics?
vanster
80 5sp
