928 Forum 1978-1995
Sponsored by: 928 Specialists
PLUG/DISTRIBUTOR CONNECTION
Old 11-07-2010 | 01:51 AM
928 at last's Avatar
928 at last
Default Sorry
Originally Posted by PatrickP
Rob: (or anyone)
I looked at the cap this morning when I went out to work on the car. There are no numbers referencing the plug/distributor connections that I see anywhere on the cap. Was this perhaps something done post '85 (year of my car)? Maybe I am just missing something but still need to figure out the correct connection. Again, this is the side with the number 8 cyl. Right side as you face the car.
Thanks again
Patrick
'85 auto
When I said later models, I meant S4. I'm not up on the earlier set ups.
Old 11-07-2010 | 10:46 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
posting the year of the car makes a difference on what type of ignition system is used
PJG posted a great little piece of info you should be able to figure things out from that.
Note the cap that JF posted is missing its black grounding cover,
this part must be fitted to assure errant ignition pulses are not sent to other parts or the OP
Old 11-07-2010 | 10:53 AM
Landseer's Avatar
Landseer
( Subtle and clever reference). Can be a nasty shock.
