Tire size for 7.5" (et50) and 10" (et65) x 18"
Team Owner
I have 235 front and 265 rear, but the ET 50 will push the rim out a bit
i suggest a 225 up front.
the rear will be closer to the inner fenderwell so you may want to fit a spacer after fitting, but your not going to have much room my rear ET is 58 and there is about 12mm to move my wheels out but i dont have any spacers
225 front with the et 50 wheel will be that max that you want to go. Rear I had 275's with the stock 21 mm S spacers with no rubbing. 265's should work just fine with a 1" spacer.
