Spark Plug Wires
I know that one is preferred by most and some have no problem with the other.
There are a few good threads on it.
I spent the money on a total upgrade to a coil over system. (different wires/no distributor)
New cars call it CDI
Administrator - "Tyson"
The best deal is to re-use the spark plug end. Using a simple multi-meter you can verify if they are within spec.
You unscrew them from the old wires, screw them on the new. A few vendors like Roger, 928 International and 928 Specialists sell a DIY kit for this. The spark plug end is where the big cost is.
Your have two low cost options: Buy the wire only kits as mentioned above, or buy the wires and terminators themselves and make your own wire set. The vendor for the wires and terminators was mentioned on here somewhere. Kingsborne or something, I think.
They are pricey and If I remember correctly there are about 2 different types maybe 3, you'll have to do a search.
"You get what you pay for.........."
I guess that I have always disagreed with that old saw. I would say instead,
"You very rarely get more than you paid for, and often don't get as much as you paid for."
