Oil in tps???
Oil in tps???
I'm replacing the tps on MY 86.5 and thought I'd open the old one up just to have a looksee...after carefully separating the cover from the body...oil spewed all over, the thing must have been full! If it didn't happen to me I wouldn't have believed it. Has this happened to anyone else?
Hey..its the only thing not rusted and caked with crap under the intake.
What one needs to determine is if the electrode is cracked beneath the plastic layer causing poor operation.
You boys might be doing just what I did three years ago.
Have the board dialogue.
Ignore the search.
Man, did that get me into rework mode.
Ignore the search.
Thanks for the info.
Right you are Speedtoys...maybe I should drill a small hole in the bottom and screw a drain plug in...after adding a quart of fresh oil to keep it from rusting with everything else! (it does help to have a sense of humor)
That is normal, while you have it apart, you should get two new throttle bearings with seals built into the bearing from Roger, 928sRus, they are the same as the bearings on the flappy on 87 and up manifolds. Do a search, Dwayne and Mike Frye did a write up on replacing these bearings on the throttle body. To eliminate this, I installed the 928Specialists Shark Vent system, no more oil breathing into the intake system, no oil in intake manifold anymore!
Post 28 and 29, not saying its your problem, but its worth knowing that "flush, assemble, seal and go" may not get to the bottom of some known past issues with TPS.
https://rennlist.com/forums/928-foru...-switch-2.html
