Cat rattles when pounded with fist - pics added?
While inspecting the exhaust on my 79 I was banging my fist on parts to check for security. When I bang on the cat dead center there is a pronounced rattle.
I did a search here and a general search in google and found that soemcats are pellet filled and might rattle. I don't thionk my exhaust is original. Does the 79 have an O2 sensor? I am not seeing one of those either.
Inventor
I don't think it should rattle.
This is what a '78-'79 cat looks like. '80 looks more modern and has an O2 sensor. '81-'84 have air injection piping. AFAIK, '80-'84 should fit '79.
![](https://i.ebayimg.com/05/!B4M9m2wEGk~$(KGrHqIOKjgEyNHbZhEpBMo9Ki6+T!~~_12.JPG)
http://cgi.ebay.com/ebaymotors/ws/eB...m=120632053507
'78 has a big body crossmember which connects the non-frame rails so I don't think a later cat will bolt on without modification.
![](https://members.rennlist.com/porken/78Cat&Crossmember.jpg)
Been selling Twinkies on Ebay,
have some extra cash right now.
Pt says to MD: Doctor, it hurts when I do this."
MD to Pt: "Then don't do that!"
'79 manifolds will have an undrilled flange-tab casting on the downward travel. No O2 into cat IIRC. And the stock cat is a honeycomb affair, no pellets.
Team Owner
please post some pictures it will make an ID of what you have possible
in general a rattling cat means its time for a replacement.
Most cats Ive ever seen were honeycomb either precious metal or ceramic, im not familiar with pellet filled cats. Either way they rattle when they have broken apart and that means its time for some new ones.
Eventually the cats will clog up and the car wont run.
Former Sponsor
Chronic Tool Dropper
Remove a few bolts at the rear flange and use the M1A1-01 visual inspection device (aka eyeball) to see if the honeycomb has clogged or melted closed. Ceramic honeycomb with metal coating. When overheated, the honeycomb sections melt closed. Usually starts at the front, but you should be able to see some from the rear if it's severe. If nothing else you can slide a piece of fine safety wire through a few of the cells and see if they pass through. Melting starts at the area in the fron where the gas first first passes into the honeycomb, so pass the wire through off to the side of the rear centered flange.
Does Texas test for HC and nitrates when yearly inspection is due? I usually just punch out the cat and get a few free ponies. When inspection time rolls around you can add 3oz acetone/10 gal 100% petrol and you will blow better HC/nitrate #s than if you had a brand new cat.
oh, they might run, but when they do run, they will have flat spots in acceleration. frustrating. my 79 track car had this, we just replaced with a exhuast shop cat, hack job.
however, if you get headers, i do have a nice cat that mounts to the devek level 1 headers and then to the stock exhuast system. let me know if you are heading the header direction and are interested in the cat to fit that system.
Here is the verbiage from the Texas Vehicle Inspection site:
If installed as original equipment by the manufacturer, the catalytic converter will be considered a part of the exhaust emission system on all 1984 and later model vehicles. It will be inspected as a part of the exhaust system on prior to 1984 model vehicles.
The catalytic converter will be considered as a part of the exhaust system on all vehicles prior to 1984 year model and will be inspected only visually (if present) for leakage. On 1984 and later model light truck and passenger vehicles, the catalytic converter will be checked for presence and leakage. Flexible tubing which meets the requirements listed below may be used anywhere in the exhaust system.
NOTE: Inspection of exhaust systems covers the discharge of exhaust fumes and is not concerned with the noise level.
Which vehicles are required to have the emissions test?
Vehicles 2 through 24 years old OR upon expiration of the two-year initial inspection sticker.
Punch it out and weld in an adjustable washer on a thru bolt for backpressure. I've done this to many bikes an a couple of cars
Here's a very good write-up, same goes for any exhaust system... you'll just need a bigger washer
http://www.nightrider.com/biketech/exhaust.htm
Neither of my OB's have cats, the 78 has a Y-pipe into a borla cat back system, and the 79 has a factory 2 into 1 muffler located where the cat would be on a US model into a resonator and a homemade RMB. Technically, I should fail the visual inspection on the 78, but haven't so far in two years. Not really sure how the 79 made it into the country without a cat being added.
I say replace the cat with a Y-pipe, and remove the air pump.
And I was just about to suggest a Y-pipe the same diameter of the front collectors.
I didn't fall victim to the "bigger is better" crowd doing the 948 swap. I ran 2.5" exhast all the way back to a straight thru Magnaflow with NO cat and I have ZERO issues throught the RPM range.
Actually the only issue I have is keeping the lightweight beast in a straight line....check the post mid-page....No cats allowed
http://944hybrids.forumotion.com/944...ight=nailed+it
