Surcharger kit recommendation
#211
Administrator - "Tyson"
So far so good.
I agree the best route to take is larger injectors and a custom chips via a Shark Tuner.
Ditch the FMU.
#212
Supercharged
BTW, everyone thinks installing the SCer is the hard part, but it's not. Getting a reliable tune is probably 80% of the work.
#213
1 Post
FMU is already ditched!!! It will not be a part of any of the setups. Its just in the picture because that is how I started and it worked well for development purposes. But I learned fast it's not the way to go.
For sure AO... I am gaining some serious knowlage on fuel injections systems lately. Dialing everything in and doing it correctly takes a lot of time!!!!!!! The idea is to make the install easy, with the sytem being depenable and powerfull, for the end user Oh yeah ... and not cost 2 arms and 1 leg.
#216
#217
I believe they also make a C38-92, which is the same as the 91 but with a little larger inlet. Both units have a slightly longer outlet snout than the std C38 units, if I remember correctly.
I was messing around with a C38-91 last fall. Nice unit, I really like the compact diameter which is what initially caught my interest.
I had a pretty interesting inlet/air filter design for what I was contemplating; I'll see if I can find the templates and post a pic.
#218
1 Post
COME ON GUYS YOUR STEALING MY THUNDER HERE!!! LOL
It's all good , But maybe I should have waited a couple more weeks before saying anything on here. Then done a proper product launch and introduction.
#219
Dan
'91 928GT S/C 475hp/460lb.ft
#220
If it creates low heat, you could use a fuel with very good cooling effect and run higher boost without an intercooler.
#222
#224
#225
Captain Obvious
Super User
Super User
