928 Forum 1978-1995
Sponsored by: 928 Specialists
Best way to mount this Vent?
Old 09-19-2010, 05:41 PM
Ducman82
Ducman82's Avatar
Default Best way to mount this Vent?
So i dont like rivets, to....Off roadish. i was thinking Sikaflex or some other kind of bonding agent..... thoughts fellas? and yes its off center. i just set it in the hole for now.
Old 09-19-2010, 07:11 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,278 Likes on 1,263 Posts
radius the corners of the hood cutout this will prevent cracks from forming, Structural adhesive ought to work.
do your homework on bonding to bare aluminum, you may have to paint the hood first then apply the outlet
You could also bond some type of attachment to the underside of the outlet and use DBT to fasten the outlet and also attach with a mechanical fastener
Old 09-19-2010, 08:34 PM
Ducman82
Ducman82's Avatar
i was thinking about some kind of bolt "bar" that i could attach to it, then screw it down. the corners were drilled holes that i connected, so it should not crack. i think what i might end up doing is paint, then add the scoop (might paint it as well). im not sure how the paint would turn out if i had it painted on the hood, with that edge and all.
Old 09-19-2010, 08:41 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
paint both pieces separately
Quick Reply: Best way to mount this Vent?
