Aiming for 320rwhp with my 86.5
#46
Does the Euro "low compression" 85/86 32v motor have a throttle body smaller than the S2?
The US 85/86 32v use essentially the same size throttle body as the Euro S2.
BTW no need to guess on flow losses, somebody could just measure the pressure at various points in the intake system. Ideally measure both temperature and pressure.
#47
All S 2 use a 80 mm TB.The S 3 TB is 75 mm.
The look from the outside is the same.
Left S3 right S2
The S3 tb is conical to the plate and machining the tube isn´t a good idea because the tube break! Ask me why I know! :-(
Left S3 right S2
#49
Former Sponsor
We have a $75.00 baffle that fits under the filler neck that virtually eliminates the oil consuption issue, on the S4 engines. Should do the same for the S3 engines....
#50
Inventor
Note that to use a S2 throttle body on a S3, you have to swap the throttle plate axle and relay lever, springs.
If you have a donor '86 S2 TB, you may only have to swap the relay lever as the cam gate (which controls the opening rate of the throttle) on the '86 should be the same for S2 and S3.
#53
Inventor
AFAIK, there are no ROW '85 32V. All S3 TBs are 75mm...except Karsten's.
