A "bright" idea: illuminated window switches ** Important order info added **
#47
The tactile side is resolved. This is an option that will carry a minimal surcharge because I have to add an extra layer and some more setup and laser time. But it's there for those who need/want it.
The DEI modules simply replace the limited factory window controllers. The hookup will be simplified by the supplied custom harness and guide.
It brings window control in line with the current production cars.
One is for both windows, the other is for the sunroof.
Current price is around $40.00, Hans will be able to quote a more accurate price for those.
And yes, both the switch panel and those controllers will work with all years of 928 and both right and left hand drive cars.
Paul
Paul
Do you plan to offer the DEI's (and if so, I'll remove my price look-up from the other post), or should we assume to by them on our own?
#49
Former Vendor
I don't yet, but I can take some. The pictures at the top of this thread, are taken with the factory metal bezel for the factory switches. The panel is designed to fit the factory bezel and line up with the bottom of the radius.
Thanks Sterling. The DEI modules will do exactly that. Hans will be able to explain how.
We can supply the module, but we have not forced the issue since you can get a better price on eBay. We would rather just point people in the right direction.
I'm not sure why, but the guy on eBay sells them cheaper than our cost as dealer.
The prices on your link is probably the MSP, because is it much higher than the current market price.
What finish are you interested in Jim?
Paul
PM sent I will take one.... does anyone know if the DEI modules can take an input from an alarm, so you can open your windows from a key fob? The factory system in my 90 model will allow me to open the windows and sunroof from the drivers key... I'm assuming the DEI module will have imputs to allow this to be used?
Paul
#50
Paul,
You are the MASTER of all things leather... is there any way you could actually make a cover for the thing in leather with round cut outs for each of the icon's...that would be a heck of an easy tactile solution for those who want leather... Sounds like it would work GREAT in my '92 GTS (you will recall it has navy blue leather! ;-) I might have to get one of these set ups for that car at some point!!!! Along with the center console carputer! YEE HA! I probably need a job first though! Ha ha!
#51
1 Post
Hi Paul
You have made me think hard now with what you said about DEIs...
I have a VERY fancy alarm system a Clifford 650 with EVERY add on possible..it talks (system armed etc) , it has remote starting and lots of other functions....but also it does shut both windows and the sunroof.... which I assume means it has a dei fitted...
My problem is that the fitter when asked to give me remote "one touch open" as it had remote close on windows/sunroof, said that due to the 928s wiring it could not be done ?
All the best Brett
All the best Brett
#52
Thank you. Learned my new thing for the day.
Must have been a pretty early design change then (81 maybe?) as my 82's wiper switch is located there.
I thought the factory might have used that location on some later models for hatch release. Makes sense not to be located there though.
I think you are confused. There are no 928's from the factory with a hatch release switch there. The rear wiper switch also originally lived on the Pod - and was relocated to the console area by a complete ergonomic idiot. It really does not belong there - however - its more stupid still - the active end for wiping the rear glass is the same end that opens the windows/sunroof on the adjacent switches....
I would venture that if you intended to operate the rear wiper - its pretty certain that you do not want the sunroof to open by mistake...
I think if the switches are located there (and I'd rather they were on the doors) then they should all be for window type functions...
I'd propose L & R Windows, sunroof and a button that (express) opens or closes all three with one press.
Alan
Alan
#53
Former Vendor
Paul,
actually, the very first plan for this project, was indeed to make the cover in leather. And it is possible. However, leather being what it is, simply does not cut or engrave cleanly enough, for pictographs as small as these, to be clear and sharp.
I ran into the same thing for the HVAC controls. That is why the design evolve to what it is now with a control panel surrounded by stitched leather.
When it's all said and done, this is a lot sharper and will look right at home, whether you have an updated interior or a stock one.
Paul
#54
Former Vendor
Hi Paul
All the best Brett
All the best Brett
I will let Hans tackle this one. Clifford is the competitor to DEI and it would appear the similar modules are integrated into your alarm. So it might be possible for our panel to interface directly with your alarm. But since Hans designed the electronic interface board, I will let him jump in.
Just as I will be prepared to do custom work on this and the center console upgrade, I know that Hans will also offer his services for those who want custom applications, both with this panel and with the carputer and HVAC projects.
Paul
#55
Agreed, probably retail $. The link below the pic is Amazon and is close to your pricing.
I, personally, would by from you... esp if it included a properly terminated wire harness.
I would be the guy asking for ultra stock looking. Black texture, white LED, and custom graphic.
I'm also the guy waiting for the new HVAC console (and pricing thereof). I want a modern cohesive look.
I believe the two offering may do well individually but that is something I will need to see.
#56
1 Post
Hi
Just a comment regarding pricing..... I suspect Paul thinks he is expensive but I do NOT...
In the UK for this sort of stuff, it would cost you hundreds and hundreds of UK pounds...as an example my fancy alarm system cost me well over £1000....
Besides which I would rather buy from Paul who even in the UK has an excellent reputation for stunning quality
All the best Brett
All the best Brett
#57
Former Vendor
Hi
All the best Brett
All the best Brett
Paul
#58
Former Vendor
red, green, blue, amber and white of course.
But standard LED will also fit the holder and the choice of color there is infinite.
The panels will come standard with white, unless you request on of the other 4 colors. There is no extra charge for color.
Paul
#59
I will have limited access tonight (prior engagements) but will try and follow up tomorrow morning.
Brett-
Cilifford is owned by DEI, so you likely have the DEI modules installed, or something similar, which can be used. Take a look and see if your installer left you any documentation, or if the model is listed in the receipts. You may also have a "Twindows" module instead, but believe I can make that work too (may require a relay or two at worst).
Jim-
I have a friend who is an authorized DEI dealer, and I can get modules from him at his cost. However, even at his cost, the price is higher than that of ebay or amazon... etc. It will be something that we can offer, and they will have full warranty, but the simple fact is that we cant compete with other online pricing on the modules themselves. I may try and work something out in the future to try and reach a reduced cost, but till then, I can sell you a unit at low-volume near dealer pricing or you can save a couple bucks by purchasing the units on ebay and then sending me the harnesses via USPS and I will modify them for you for the cost of return postage (only applies to standard installation, custom work will be done at a reasonable hourly rate).
Paul is correct on the LED issue. The higher and more focused the LED, the better the results are. The included colors are designed to have the best characteristics, but others certainly can be used. Any standard T1-3/4 sized LED will fit in the socket. If you have a lighting kit from another vendor here on rennlist, it may be worth asking if they can source a matching T1-3/4 from the same series as used in the rest of the kit. That way you know the color is an exact match. Replacing the LED is a very simple process, but it will always be easiest to install the proper version with the panel, as most of the work will involve removing the switches from the console.
I will try and get on later tonight, but likely other questions will be answered in the morning.
Thanks,
Hans
Brett-
Jim-
Thanks,
Hans
#60
Former Vendor
Paul,
I can try and make a sample for you to see. But I will need it back once you are done, because I have a limited supply of light panels from our fiber optic supplier.
Paul
