928 Forum 1978-1995
Sponsored by: 928 Specialists
new boot
Old Sep 2, 2010 | 09:36 PM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
When I was a medical student in Texas we took care of lots of alcoholics who would go into liver failure and develop GI bleeding. There was a special balloon catheter you could put in the esophagus that you could blow up to compress the bleeders. Problem is, alcoholics in liver failure get loopy (from high blood ammonia levels) and they tend to pull out things like IV's and catheters.
So when you ordered one of these catheters from central supply, it would come in a plastic bag with a football helmet, so you could strap it on the patient's head and tape the hell out of the catheter to the facemask so they couldn't pull it out.
That was the inspiration for the personal protective gear for peter while he pulls off his ****.
Old Sep 2, 2010 | 09:45 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
Originally Posted by jon928se
The easiest and safest (to body and shifter linkages) way to get the shift **** of the lever is to pull the old boot up exposng the lever.
Clamp molewrench/visegrips onto the lever 1/4" below the **** then pry the **** upwards using a small spanner/wrench that fits closely around the lever.
Step 2: Retrieve **** from across garage after it goes through windshield.
Old Sep 3, 2010 | 10:36 AM
9two8's Avatar
9two8
Originally Posted by WallyP
Applying excessive pressure up or down on the gearshift can cause problems - the plastic bearing just forward of the shifter will break, and if the front shift rod cup is worn, it can pop off of the ball when you push down.
Liquid dish soap can help with installation.
...guess I got lucky Wally
Ken
80 928 S
5 Speed
UK
Old Sep 3, 2010 | 01:12 PM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
"...guess I got lucky Wally "
Most people do - at least as far as they can tell. Often some of the sloppy shifting folks experience is due to the plastic ring being broken in the rubber shift rod mount located just forward of the shifter.
"The easiest and safest (to body and shifter linkages) way to get the shift **** of the lever is to pull the old boot up exposng the lever.
Clamp molewrench/visegrips onto the lever 1/4" below the **** then pry the **** upwards using a small spanner/wrench that fits closely around the lever. "
Sounds like a plan...
