928 Forum 1978-1995
Sponsored by: 928 Specialists
Blower box flap reseal Who did it??
Old 10-10-2020, 08:36 PM
hwyengr
hwyengr's Avatar
Originally Posted by Mrmerlin
Thanks those were the pictures i was looking for
the pictures are at the end of Dwaynes writeup
Stan,
Did you ever split your blower box to re-seal the flap? If so, how did it go? I’ve got a used box from Intl that needs new sealing all around.
Old 10-11-2020, 06:17 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,548 Likes on 1,430 Posts
No I don’t split the bo just reseal the blower housing so water won’t leak onto the CE panel
Old 10-11-2020, 01:22 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,784 Likes on 1,355 Posts
I did this on Dan Hebert's Turquoise car but didn't do a writeup on it. Here's a thread that covers some of it.
https://rennlist.com/forums/928-foru...l-1990-gt.html
And a video in post #18 of this thread that shows the action of the mixing doors:
https://rennlist.com/forums/928-foru...ter-valve.html
Old 10-12-2020, 12:28 AM
GregBBRD
Former Vendor
GregBBRD's Avatar
Received 2,477 Likes on 1,468 Posts
I've done several. Almost every single vehicle now needs this service. Keeping heat on the hot side and getting only cold air is almost impossible, when the foam deteriorates.
The tough part is finding the correct material to use. I ordered several different types, thicknesses, and widths of foam before finding the appropriate stuff.
The actual work is pretty simple....once the HVAC unit is out of the car, which takes a minute or two.
Old 10-12-2020, 03:20 AM
PorKen
Inventor
PorKen's Avatar
Default Last winter's cabin fever project
One of these dayz...
Just need moar time, better drafting skillz, and a place in town with a large format 3D printer...
Volvo LA79 pollen filter? Sure!
Old 10-12-2020, 09:42 AM
ddire333
ddire333's Avatar
If that was last winter then we have a lot to look forward to with all the lock down time this year
Old 10-12-2020, 10:55 AM
hwyengr
hwyengr's Avatar
Yeah, I'm doing the center console one too, but I was mostly asking about the footwell box. Herman K once posted a few pictures about splitting the footwell box apart to re-seal, and then epoxying back together, but there weren't a lot of details. I was hoping someone else had done something similar, or had a good tale about being able to re-seal with everything intact.
At least I figured out why my box was leaking after strip caulking the hell out of it. This ace mechanic right here didn't put the reinforcing metal strip back in place.
Old 10-12-2020, 05:12 PM
The Forgotten On
The Forgotten On's Avatar
I've resealed 2 of the footwell boxes without cutting holes. You just need to slide the metal rod out of the holes on the flap and then pull it through the grill.
Easy enough to do, but a bit fiddly. I've also resealed the main HVAC box using closed cell foam. It's fairly easy to do as well, just takes time.
Fortunately you can remove the flap assembly from the box with the back half still in the car, it just slides out, or at least it did on my 81 after removing the heater core.
Neither job is fun but the footwell one is worse purely from the mess all the crap stuck behind it make when you push it into the car.
Old 10-12-2020, 06:07 PM
hwyengr
hwyengr's Avatar
Hang on, are you talking about resealing the actuator diaphragm or the flap itself? I'm trying to re-line my flap with closed cell and I can't see any way that it pops out of the box without breaking it open.
Or are you saying you can squeeze the foam through the top hole, and are able to reseal it while the flap is in place?
Old 03-29-2021, 05:00 PM
Smitje 928
Smitje 928's Avatar
'87 S4 Automatic
I'm in the process of replacing all the foam in the Airco Unit and the blower box, and am curious if anyone ever tried to separate the top and bottom part of the box?
They appear to be glued together, so would it be possible to use a very thin Dremel plastic cutting wheel and cut through the glue at low speed?
Thanks!
Manfred
Old 03-29-2021, 05:31 PM
linderpat
linderpat's Avatar
Received 2,411 Likes on 1,307 Posts
I have done this job on two of my prior sharks, but it has been a really long time. I am going to do it on my current red 85, since I'm pulling the CE panel and other items for maintenance anyway.
What I cannot remember - can the work from the top be done without removing the hood as per Dwayne's write up? It seems to me it can be. (yes I knowe that having the hood off makes it easier, but that isn't my question).
Thoughts?
Old 03-29-2021, 10:40 PM
Kiwi928S4
Kiwi928S4's Avatar
I have done both boxes on my 91 S4. They are a bit fiddly but quite doable. Both boxes have to come out. The center console one comes apart once the clips are removed and then you have full access to the evaporator and flaps. clean and replace the foam sealing edges to the flaps with 2mm closed cell black EDPM foam - glued into place with good contact glue. The footwell box - you pull the hinge pin out and can get access to the flap with tweezers to glue in the foam - fiddly but doable. Dont cut anything off the box or butcher it. Take your time and reseal it back into place with Eastman black flexible sealing strips.
I have photos if you want to PM me
Cheers
ken
Old 03-30-2021, 12:18 PM
hwyengr
hwyengr's Avatar
It didn't seem like it would be possible as I've got very broad wrists, but with judicious use of goo-gone and some patience it was possible to remove and replace all the old foam just reaching through the blower hole. Not a comfortable process at all, but it beats trying to glue the halves back together.
Quick Reply: Blower box flap reseal Who did it??
