928 Forum 1978-1995
Sponsored by: 928 Specialists
Compression ratio?
Old Aug 25, 2010 | 12:16 AM
Iwanna928's Avatar
Iwanna928
Default Compression ratio?
I have read many times about the CR of a hybrid being 10:1 using a 85/86 block with euro heads.
Does anyone know what the same block would be using US heads?
Old Aug 25, 2010 | 01:33 AM
IcemanG17's Avatar
IcemanG17
the stock 5.0 32V pistons have a CC of about 6.5...but will add a touch more with the two valve cutouts...the USA head vs the Euro 16V is 3.5cc more so it will be a touch less compression....
Old Aug 25, 2010 | 11:59 PM
Iwanna928's Avatar
Iwanna928
Thanks!
Old Aug 26, 2010 | 12:09 AM
Fabio421's Avatar
Fabio421
Man of many SIGs
If Brians correct, adding 3.5 cc's to the combustion chamber will yield a comp. ratio of 9.35:1 by my calcs. I wish I had seen this thread sooner. I just dropped a pair of US 4.5L heads and a set of Euro S heads off at the machinist this afternoon. I can cc them when I get them back.
#'s used were:
Head Gasket @ 1.5mm thick X 100mm diameter
Piston: -6.5 cc's ( this number will increase in your application due to the necesity of larger valve reliefs.
Chamber: 56 cc ( I arrived at this # by adding 3.5 cc's to the known Euro S #'s of 52.5 cc's )
Old Aug 26, 2010 | 01:16 AM
mark kibort's Avatar
mark kibort
yeah, the 85 pistons with notches are about 8ccs. euro heads vs US heads was 47cc vs 53cc if I remember correctly.
Old Aug 26, 2010 | 09:02 AM
Ian928's Avatar
Ian928
I know we have argued about this before Mark, but I am sure there is difference between Euro S and "S2" (84-). I have two sets of Euro S heads(from 1980), all 4 measures 52,5ccm. I am pretty sure the 47ccm heads came in 1984.
Old Aug 26, 2010 | 09:24 AM
LT Texan's Avatar
LT Texan
I measured 48cc's on my '86 Euro S heads. Just measured on 1 chamber, and the measurement was a little bit rough.
