Got me some BIG Reds! Whoot Whoot!
Supercharged
Finally took the plunge... Thanks to Hans for parting with these.
Need refinishing, but they should clean up nicely.
Anyone know the the best deal on rotors?
Basic Sponsor
I will start the bidding - I have cast hole Sebro for $169.95 per side.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Supercharged
They've been sprayed once before, but I'm pretty sure they are red from the factory - just full of brake dust.
Roger- That's an awesome price. Best I've seen elsewhere has been near $200 ea. Sold. Will call you one Monday to order.
Not sure about now but a few years ago I bought factory 964 turbo 3.6 rotors for about 160 each from Sunset. The 928GTS blanks were a bit more expensive.
I recall that you need longer bolts to mount them....I was looing at where the boltheads covered the caliper and it looks black.. also get the paint off the crossover pipe and check the piston sizes for leading edge orientation....911 and 928 are upside down
The crossovers do need to be swapped. Those calipers were still in 993tt configuration (I last used them on my Audi).
Bolt should be a standard M12, and a lot cheaper at the hardware store than the Porsche dealer. I think I have a spare set that I can send you if you cant find some local.
Roger - great price on rotors.
Supercharged
Oh, maybe piston size and location comes into play? 'Cause they look like you can swap them around.
Correct on the piston size leading edge of the pad gets small piston.....big at the trailing edge for more clamping. All the Brembos have different piston sizes like that.
Team Owner
Brad you will need to pull the calipers off and swap them side to side also transfer the crossover tube from tops to the bottoms
