Who sells a good Adj, FPR
Archive Gatekeeper
Joe-
Greg had me get a Kirban FPR from Mark A. for the stroker, works great.
http://www.mailordercentral.com/928i...10%20198%20ADJ
![](https://webfiles.uci.edu/redwards/public/Kirban%20and%20LR%20damper%20replaced%205-1-10.jpg)
![](https://webfiles.uci.edu/redwards/public/Facotry%20vs%20Kirban%20FPR-%20top.jpg)
![](https://webfiles.uci.edu/redwards/public/Facotry%20vs%20Kirban%20FPR-%20side.jpg)
Rob,
I got your PM thanks![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Can you confirm the Kirban is a "direct" replacement and would
not need those custom hose you have in the picture ?
You da man ! thanks ..
928 specialists has the 88-95 adjustable fuel pressure regs available on sale for $125
https://www.928gt.com/default5.htm
Archive Gatekeeper
Good price for the adjustable FPR, wish I'd shopped around....
Joe, the dimensions of the threaded connections on the Kirban are identical to the stock FPR, so you ought to be able to use the stock 'U' line and the line to the fuel cooler.
Rob -- thanks, I'm also changing all four fuel lines, so thats good to know the stock ones fit.
I've got a new MAF w/boot up in the attic, I'm really temped to pull the manifold and give it
a squirt of paint then change the knock sensors and a few other rubber hose's then slam it
back together quick before I go any deeper -- Jeeez its a slippery slope -- helllllllp .........
