My odometer stopped working recently. The repair shop is telling me that the brown/orange gear on the back of the speedo head unit is completely striped. Is there a repair kit available or will I need to buy a new speedo unit? The speedometer works fine, just the odometer has stopped working. Any thoughts are appreciated.
you can buy a new gear for about 25.00 then either install it yourself, its a bit tricky.
or pay the man to install one .
Usually about a 3 hour job for a shop,
but if your proficient it can take 45 mins
you can buy a new gear for about 25.00 then either install it yourself it a bit tricky or pay the man to install one usually about a 3 hour job for a shop but if your proficient it can take 45 mins
Yea, 45 minutes to take the pod out, get the needles off, take the speedometer off, take it apart, clean all the little bits out, inspect it and then replace the gear and put it all back together.
I have done several of them, I wish I was half a fast as you were.
I replaced mine and it stopped working again shortly. I redid the work and also put some thin washers between each number to shim it and keep proper spacing. It has worked flawlessly since then, almost a year.
I am getting ready to do mine (I have actually been putting it off for a while now). What washers did you put in?? Just the thinnest that you could find?? Also, any idea why it was necessary to put in shims?
