928 Forum 1978-1995
Sponsored by: 928 Specialists
New Product: High-Performance Intake Runners for the 32v 928
Old 07-09-2010, 02:45 PM
  #31
mark kibort
mark kibort's Avatar
How did you get near 11" for runners that seemed to be 3" tall? are you adding in the distance to the inlet?
also, why do you want Max HP to be at redline,not before?
also, what is "LSR"?
thanks,
m
Originally Posted by Carl Fausett
Kibort: the final total runner length of these runners for this application came out to 10.85". Its not as short as you think. And it was not left to chance. To have a shot at the LSR, I need max HP at redline, not before it. So I would agree, my configuration would be different than someone elses.... but then thats the whole reason for seperating the intake runners from the plenums. Now you are free to finish your manifold as you need for your application.
mark kibort is offline
Old 07-09-2010, 02:48 PM
  #32
karl ruiter
karl ruiter's Avatar
Just shows the payoff of having a passion for your work. You get to have fun, and end up with great products. Congratulations, Carl. I wish I lived some place where I could put a 800hp 928 to use.
karl ruiter is offline
Old 07-09-2010, 03:26 PM
  #33
Tim Murphy
Tim Murphy's Avatar
I have had these manifolds in my hands and all I can say is that they are very nice and very high quality.
I don't know much about plastic but it seems that Carl has done his homework with this.
Very cool product!
Tim Murphy is offline
Old 07-09-2010, 03:32 PM
  #34
DR
Rennlist Sponsor
DR's Avatar
Very cool product!
Tim,
Next time you have a set in your hands.... RUN.... and ship them to me PLEASE :-)
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
DR is online now
Old 07-09-2010, 04:08 PM
  #35
SeanR
SeanR's Avatar
Very nice set up. Impressive.
SeanR is offline
Old 07-09-2010, 04:20 PM
  #36
svp928
svp928's Avatar
MK, since you had the Holbert LSR car, how can you not know what LSR means? !!
11" is from the back of the valve, measured as it should be. Carl wants max power near redline so he doesn't have to have a set of 1.8 rear gears made....
The single-length inlet will make max power at a one particular rpm- this is what Carl wants. For a road-racer, a variable-length or multi-resonance-tuned intake system makes better power at all other rpm ranges. The flappy and unequal-length runners make the S4 a 2-stage system. I believe the GT3 is 3-stage system. Variable-length trumpets provide for a wide range of tuning, but are $$$ to make and tune correctly.
Louie and Mike Simard can probably give you more specific info on how their ITB's are tuned...
svp928 is offline
Old 07-09-2010, 04:21 PM
  #37
Carl Fausett
Developer
Carl Fausett's Avatar
Thanks guys. Thanks very much. Somewhere between 2 and 3 years ago I set out on the general project that I wanted you guys to be able to hop-up a 928 just like a SBC, with readilly available parts right off the shelf.
A look at the new Products I have posted shows I have been methodically chewing through the engine from induction thorugh exhaust.
Its nearly all there now.
Carl Fausett is offline
Old 07-09-2010, 04:25 PM
  #38
Carl Fausett
Developer
Very well said.
FYI, there is 3.47" from the back of the valve to the intake manifold flange surface. That is included in all intake runner length calculations.
Old 07-09-2010, 04:26 PM
  #39
dcrasta
dcrasta's Avatar
Those exhaust headers are art man .. I would run them till they turned gold then hang them on the wall..
dcrasta is offline
Old 07-09-2010, 04:27 PM
  #40
svp928
svp928's Avatar
Forgot to say-- nice job, Carl!
svp928 is offline
Old 07-09-2010, 06:34 PM
  #41
Iwanna928
Iwanna928's Avatar
Maybe its time for me to start looking for a 87 plus parts car so I can put all these goodies on my 79! Or buy my wife a S4 auto!
Carl You are the man.
Iwanna928 is offline
Old 07-09-2010, 06:42 PM
  #42
Carl Fausett
Developer
Kibort:
that flow test is pretty meaningless, right?
Not at all. Simple, yes (flow-testing an intake runner is pretty simple) but not meaningless.
The formula for a Sprint Car engine is fairly well defined, and we know that in order to make 800 HP from a 400 ci SBC engine with 4-valve heads we have to move 360 CFM through the heads. I wouldn't say its cook-book engineering, but it is a pretty good yardstick, and it tells me that I also need to flow 360 CFM through my heads if I want to produce 800 HP with my 6.57L 928 motor (401ci)
So we flow-benched our heads, cams, and big valve package to make sure they would flow at least 360 CFM, and we got it.
And we tested our intake runners to make sure they would not be a restiction.... they have to flow 360 CFM also to support those heads. We worked them until they DID flow our numbers, and then we stopped.
Its a matched system: intake, intake valves, heads, cams.
In order for me to hit the HP number I want, they all have to flow their numbers.
Thats what we were testing for. Certainly not meaningless!
Old 07-09-2010, 07:02 PM
  #43
mark kibort
So, It does make sense. I get it now.
Hey, in thinking about it, I have actually run the S4 without the covers and with the 2 throttlebody set up. no gains were found, so it stands to reason, even if the rest of the intake is bad, the runners are worse.
Sounds like you got it all figured out. again, it would be interesting to see what that set up does just bolted on a stock NA S4. any plans?
Steve: LSR...............oh, I get it now, never heard that abreviation.
Kibort:
Not at all. Simple, yes (flow-testing and intake runner is pretty simple) but not meaningless.
The formula for a Sprint Car engine is fairly well defined, and we know that in order to make 800 HP from a SBC engine with 4-valve heads we have to move 360 CFM through the heads of the 400 cubic inch V8. I wouldn't say its cook-book engineering, but it is a pretty good yardstick, and it tells me that I need to flow 360 CFM through the heads if I want to produce 800 HP as well with my 6.57L 928 motor (also 401ci)
Old 07-09-2010, 07:37 PM
  #44
Ducman82
Ducman82's Avatar
Very great work Carl and team! cant wait to see what you do to 16v when you get to it! just like your spider for your car!
Ducman82 is offline
Old 07-09-2010, 08:46 PM
  #45
IcemanG17
IcemanG17's Avatar
More 928 ****...super cool stuff.....makes me glad I don't have a 32V 928 to install it on!!! One less thing to buy!!
IcemanG17 is offline
Quick Reply: New Product: High-Performance Intake Runners for the 32v 928
