Close call.........siezed WP on the side of the Rd.
#32
Basic Site Sponsor
Basic Site Sponsor
Which is why so many of these engines have had the valves hit the pistons when the water pump fails?
The timing belt normally breaks long before the engine overheats.
Anyone that I've talked to (and there have been more than a few) who have had this failure chose to ignore the timing belt light.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#33
I have seen a couple of waterpumps fail. And they all have made a fair amount of noise with burnt rubber smell, as well as a quick rise in temp.
They were all turned off in time.
#34
How did you get the driver side timing belt cover off without taking off the PS pump bracket? I fought with that for hours!
As far as the block is concerned, keeping my fingers crossed. I guess if you see shavings in the coolant when you drain it you will know for sure.
#35
Captain Obvious
Super User
Super User
I don' remember hearing any noises from the WP but my car is anything but quiet. What I can say for sure is that the belt light came on way before the temp gauge went into the red and tripped the warning system again. There was at least a couple minutes between the two events. To me this is an eternity when the timing belt is slipping on a siezed pulley. The weather conditions were the worst too as the heavy rain took all my attention to drive and I wasn't looking at the gauges like I normaly would. Only when the ! started flashing is when I looked down.
#36
Captain Obvious
Super User
Super User
I used the force! Actually I've unbolted the pump and used a little.....maybe a bit more than a little, force and some manouvering of the cover, to get it off. I did this last year too when the new head gasket went in. It will go back in the same way too but I'm taking the bottom timing belt cover off so the PSbracket and the SC bracket will have to come off.
#39
Captain Obvious
Super User
Super User
Started the teardown today. The old belt is off and the waterpump bearing has complelty failed. There is a lot of play in the pulley. Haven't got far enough to drain the coolant and remove the pump but that will come in the next day or so. There is melted rubber everywhere. Anything that the belt was in contact with has bits of melted chunks compressed to it by the spinning belt.
I had the remove the SC and the bracket, the balalncer needed a few more mm to clear. This is something I was hoping it wouldn't do during the build but, at least now (after 5 years) I get to re paint the bracket and polish up the SC. The SC haven't been off the car since I first went on and that has to be at least 5 years. All considered there will be a bit more more to clean up the pullies but I consider myself very lucky.
#42
Team Owner
DOH... get new parts
#43
The smooth pulleys I would replace good idea anyway. The toothed ones (if the anodizing is still really good) you could try putting them in the oven, heat them up and then see how easy it comes off. If it doesn't work just replace everything. A torch can damage anodizing very easily.
#44
Captain Obvious
Super User
Super User
The dilema is that the smooth pullies are fairly new. My problem is the toothed oneas. They are not worn at all, just have melted rubber bits on them. Just remembered, I do have a complete good spare set on the spare engine. I think I'll use those.
