928 Forum 1978-1995
Sponsored by: 928 Specialists
How do you Lighten the Steering?
Old 06-13-2010, 03:56 PM
brianrheffron
brianrheffron's Avatar
Default How do you Lighten the Steering?
I find that on twisty but not very fast roads the steering on my 928
is quite hard work but it's OK on faster "sweeping" roads
Are there any known modifications that will lighten the steering on an S4.
I think I read somewhere on this forum that the GTS had different parts
that had this effect.
Old 06-13-2010, 04:01 PM
Chuck Schreiber
Chuck Schreiber's Avatar
100bar power steering pump.
http://www.griffiths.com/porsche/steering/
Quote from website
"If your 928 seems hard to steer in parking or slow turn situations you may want to try out new "HO" (high output) 928 Power Steering Pumps. Our HO pumps offer 25% boost in pressure output which helps reduce the torque strain on your wrists"
I put a 100bar on my 79 and it did make it easier to turn the wheel at parking lot speeds.
I think the 91's and later had the higher output steering pump.
Old 06-13-2010, 05:05 PM
Jerry Feather
Jerry Feather's Avatar
Plus one on the 100 BAR pump. And plus one on Griffiths. Jerry Feather
Old 06-13-2010, 06:55 PM
Nicole
Cottage Industry Sponsor
Nicole's Avatar
Plus a modified steering rack.
Old 06-13-2010, 07:46 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
The spool valve on the little pinion shaft on the later 'improved' rack has a softer torsion spring, plus the rack seals are improved for the higher pressure. Changing just the pump without installing the later rack, especially if the original is a worn early rack, would be an invitation to leaks. IMHO anyway.
Old 06-13-2010, 07:54 PM
Nicole
Nicole's Avatar
When we replaced my rack, we first got a ZF rebuild one that made the car steer like an older model - despite the 91+ higher output pump. We swapped it again to a Porsche rebuilt rack that was specific to the later models, and all was fine.
Old 06-13-2010, 08:27 PM
axis of evil
axis of evil's Avatar
But wouldn't this make it "spongy" at speed?
Old 06-13-2010, 08:47 PM
Nicole
Nicole's Avatar
Definitely not in the set-up on my car. It's just right with the 17" wheels.
Note that the 928 steering is also speed sensitive; it reduces power assist at high speed.
I'm not sure how it does that, though.
Old 06-13-2010, 08:51 PM
blown 87
Rest in Peace
blown 87's Avatar
I can not see how it could do that with out some type of electronics Nicole.
I have suggested to one of our resident geniuses that he should make a bar (spring) to reduce effort.
Old 06-13-2010, 08:54 PM
blown 87
Rest in Peace
blown 87's Avatar
I thought it was stiffer, not softer?
Old 06-13-2010, 11:16 PM
Chuck Schreiber
Nicole is correct.
928 was the first car I believe to have reduced power assist at speed.
With the HO pump on my 79, the car had more assist in parking lot, but kept that tight feeling at speed.
I did replace the rack right after that. I'm assuming it was correct model, ordered it from 928 Specialists.
Old 06-13-2010, 11:36 PM
blown 87
Rest in Peace
blown 87's Avatar
Nicole is correct.
What are the parts that reduce the assist at speed?
I have seen nothing on them that makes me think that.
Pump, rack and hoses is about it, rpm sensitive with pressure limiter, how can this possibly know the difference in 4500 RPM in first and 4500 RPM in fourth?
Other cars with reduced assist have electronic racks.
I have been wrong about many things, so please correct me on this.
Old 06-14-2010, 12:21 AM
SQLGuy
SQLGuy's Avatar
I think it may be as simple as rack valving that provides small assist for a small movement of the wheel and large assist when the wheel is being turned further/more quickly.
Old 06-14-2010, 02:42 AM
dr bob
dr bob's Avatar
The spool valve has one end connected to the steering wheel and the other connected to the pinion on the rack. The two ends of the valve direct fluid flow to the ends of the rack or back to the pump. Really they just meter what flows back, but it's easier to understand if you think about it putting more pressure on one end of the hydraulic cylinder as the two ends of the valve get further apart in rotation.
So a softer spring lets the valve twist more with less wheel effort, so the hydraulics do more work faster with a weaker spring.
There was another comment about 'speed sensitive power steering' on the 928. There isn't.
Old 06-14-2010, 04:15 AM
Nicole
Nicole's Avatar
Just checked my old sales literature, and here is what they said in 1983:
Originally Posted by PORSCHE
The servo-effect continuously decreases with increasing torque, making it easier for the driver to control the 928S.
The German 1983 and 1991 brochures say power assist decreases with increasing rpm.
Dr Bob: Does Glendale really have a Yacht Club??? It's a little far from the ocean, I would think...
Quick Reply: How do you Lighten the Steering?
