ISV bench testing?
With the high idle issues with the '90 GT and the subsequent 2nd pull of the intake I want to verify the ISV is absloutely in perfect working condition.
Anyone have a reliable bench test they could share?
Hi Malcolm,
When I looked into it, the 9V battery test was about it.
The ISV itself is binary, on or off. Apparently uses pulsed signals to control the idle.
Mine was seized solid. (Not the usual situation from what I've read).
Hope this helps,
Rob.
Hope this helps,
Rob.
Did you use the 9v batt outta the torch?
If you put +12V to it (short duration), it should open fully.
Use brakleen or the like to clean it out.
I use graphite spray or the like to lube it up prior to reinstall.
If it is PWM you may be able to use the built-in PWM generator on an arduino. The signal may not be strong enough, so you may also need a servo shield for it. The total package, pre-built, will probably run you 60 bucks, but then you have a PWM generator, so that could be useful...
In normal use a 100Hz PWM square wave is used to set it to the required position. The ISV is spring loaded to the closed position, so battery will allow you to fully open it, then switch off battery and it should return to the closed position without sticking.
Do any of the Bosch ones have embedded damper diodes? I have seen that on some of the Ford PWM IACs. If there's a built-in damper diode, you'll have to make sure that the polarity is correct when testing the unit... otherwise you'll just short the damper diode or blow your PWM test rig.
