928 Forum 1978-1995
Sponsored by: 928 Specialists
Mirror puck removal
Old May 23, 2010 | 03:39 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
Default Mirror puck removal
Does anyone know how to remove the mirror puck from a windshield, thanks Stan
Old May 23, 2010 | 08:27 AM
jeff spahn's Avatar
jeff spahn
Yep there is a good write up on it here somewhere I used to remove mine that involved a lighter and a long handled thin bladed screw driver. basically you warm the puck with the lighter in very, very short applications of the flame. what you are trying to do is WARM not HEAT the glue that holds it to the glass. then you insert the screwdriver in the slot on the puck and rotate NOT PRY the puck from side to side. you'll feel it as it begins to give. prying it up will break the glass. very very small rotations from side to side will become possible as you warm the puck. think on the order or many minutes to get this done.
don't just blast the puck with heat and try to go at it all at once. take your time and it will come off. you'll think it takes forever and you are right. but you save your windshield by taking your time.
Old May 23, 2010 | 10:26 AM
Dennis Wilson's Avatar
Dennis Wilson
May want to try using artificial fingernail remover to loosen the glue first.
Dennis
Old May 23, 2010 | 11:04 AM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
"May want to try using artificial fingernail remover to loosen the glue first."
If you do, I would strongly suggest that you VERY carefully protect the dash and console. Anything that will remove glue will almost certainly damage them.
Old May 23, 2010 | 11:10 AM
mx22's Avatar
mx22
How about replacing lighter with a hair dryer? Sounds like a more safe way to heat something up...
Cheers!
Old May 23, 2010 | 11:17 AM
WallyP's Avatar
WallyP
If the idea is just to heat the glue, the interior temps hit over 140 deg F in the Georgia sun.
If the idea is to develop a temperature differential between the puck and the glass, the hair dryer wouldn't work as well as the metal-to-metal heat transfer to the puck alone. (And you would want to do this with the glass as cold as possible.)
Old May 23, 2010 | 11:28 AM
blown 87's Avatar
blown 87
Rest in Peace
The problem in Georgia is keeping them on the windshield.
I have seen them taken off both ways, just be careful with a cold windshield.
Why does it need to come off?
Old May 23, 2010 | 11:56 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
PO put on a fancy mirror and its too high on the windshield it also has a nice bundle of wires that are keeping the headliner from sitting flush.
anyway I prefer the stock mirror so the new puck needs to come off
Old May 23, 2010 | 12:11 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
I will try the lighter method with some acetone thrown in for a good measure, the dash is shot so no worries about damaging it
File Type: jpg
Old May 23, 2010 | 04:59 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
well a I dabbed some acetone on the edges of the puck with a Q tip, then a few clicks of the BIC and a pair of pliers and the puck twisted right off.
Thanks for the tips, Stan
