Throttle body switches
Set the wot switch so that it comes on as soon as possible and stays active all the way to 100pct throttle. If you get it wrong it can be active at part throttle and not WOT, which is bad. Have the idle switch make contact at just idle.
i was able to set up the idle switch to turn on at just a hair before 0% throttle, and the WOT switch i got to come on as soon as it could. hope this works well. Thanks Quattro.
Its not that critial. I made a full degree template to get it right, but what you have to think about, you dont need fuel enrichment at half throttle, by the way, so anything after half, but before 3/4 throttle would be fine. I think its 70%, going on memory.
