Power Seat Failure...
Quick question on seat electrics.
Brought my 928 GT to have it detailed.
Now my 12 way power driver seat does not work, fuse in panel is good.
It worked fine before...
Any thoughts would be appreciated.
Definitely would prefer a dirty car with working seats
Could be jammed, as they prob moved it max front and back during cleaning, need to try the manual approach to break it loose?? OTH, I had one seat out of the car twice before I discovered a broken wire from some previous owner misuse.
Former Vendor
Stan,
do you have memory?
Do you have any functions working or nothing at all?
If nothing at all, flash a light under, they probably disconnected the main plug while cleaning.
Paul
do you have memory?
Paul
Might have come loose when they were vacuuming it out, reach down there and jiggle some stuff. Feel for loose wires.
Thanks, they did manually back it up, so any jam should have been resolved.
I will check with a flashlight, thanks.
Thank you.
ironically the first thing I see under there is dirt...... not what I expected to find after a detailing... No obvious wires disconnected yet.
