928 Forum 1978-1995
Sponsored by: 928 Specialists
How would you repair this?
Old May 3, 2010 | 05:35 PM
MBMB's Avatar
MBMB
Default How would you repair this?
Or would you just replace it?
Old May 3, 2010 | 05:36 PM
SQLGuy's Avatar
SQLGuy
Replace
Old May 3, 2010 | 05:38 PM
Leon Speed's Avatar
Leon Speed
Buy a new one..
Old May 3, 2010 | 05:45 PM
SeanR's Avatar
SeanR
Duck Tape it. Use the green stuff.
Old May 3, 2010 | 05:46 PM
jmrjames's Avatar
jmrjames
Super Glue
Old May 3, 2010 | 05:52 PM
auzivision's Avatar
auzivision
If you want cheap fix… use masking tape on the front to mate the two pieces then JB weld the back using a few small finishing nails in the goo for added strength.
Old May 3, 2010 | 05:59 PM
anpo's Avatar
anpo
What is it?
MBMB's Avatar
MBMB
Hey, now. It was like that when I got it; I'm just getting around to fixing it.
That's not the worst thing the PO did. Soon I'll post pics of the worst thing the PO did.
Originally Posted by Mrmerlin
call 928 international and order a used one, next time take out all 3 of the screws instead of bending it to remove the side console cover
Old May 3, 2010 | 06:00 PM
MBMB's Avatar
MBMB
928 551 137 02 Scuff plate
(near accelerator pedal)
Originally Posted by anpo
What is it?
Old May 3, 2010 | 06:06 PM
anpo's Avatar
anpo
Got it Thanks
Old May 3, 2010 | 06:09 PM
mark kibort's Avatar
mark kibort
aluminum backing plate and use rivets.
Old May 3, 2010 | 06:14 PM
depami's Avatar
depami
Depending on what type of plastic it is, you might be able to weld it. ABS is quite easy to weld. Others, not so easy, at least without the proper gas.
Old May 3, 2010 | 06:16 PM
tveltman's Avatar
tveltman
For a stronger fix, get a piece of expanded sheet metal (the kind with teh diamonds stamped into it) and lay it across the backside. Lather with epoxy after thorough cleaning/sanding.
Old May 3, 2010 | 06:24 PM
LightStriker's Avatar
LightStriker
Staples.
Old May 3, 2010 | 06:27 PM
SteveG's Avatar
SteveG
glue the pieces fitted together to a strip of felt roofing material with black silicon sealant, a small bead of same between the crack as well.
