928 Forum 1978-1995
Sponsored by: 928 Specialists
How would you repair this?
Old 05-03-2010, 06:30 PM
MBMB
MBMB's Avatar
It's certainly not the money. A used one =$4 and change from 928 Specialists.
My philosophy is to replace broken parts that are available new and repair broken parts that are not available new but are easily fixed, leaving the good used parts for those who need them. In this instance, I doubt that anyone would ever know the difference.
Unless it started to leak.
Originally Posted by Mrmerlin
A new used one shouldnt be more than a few dollars, from the crack it looks like someone bent it to get behind it and in doing so it fractured.
I must admit i am somewhat amazed that you would want to fix this instead of replacing it with a solid part especially if its going into a nice GT.......its similar to the JB welded coolant bottle that another poster is running around with thats leaking
Old 05-03-2010, 06:32 PM
antsmands
antsmands's Avatar
On the backside use some quick setting epoxy 5mins or so setting time. Put a coat on both halfs and join together with some fiberglass mesh tape. Drywall fiber glass tape has adhesive already on it incase you want to put the tape on first and then apply the epoxy. Either way will work but be sure to make sure you have a good coat of epoxy embedded in the tape. Hold steady as it cures and smooth out. Once cured you can let it setup overnight or do a second application for added strength. Let set overnight and sand smooth. Be be careful on the front side so as not to have it glob through.
Old 05-03-2010, 07:16 PM
Stromius
Stromius's Avatar
Whatever you do will look like **** in 5 years for the next owner and they'll wonder...wtf. Can't be that much $$.
Old 05-03-2010, 07:52 PM
Alan
Electron Wrangler
Alan's Avatar
Just buy a new one...
Old 05-03-2010, 08:05 PM
Don Ashe
Don Ashe's Avatar
I'd sand the back side clean, then use plastic bumper repair epoxy, it's flexible and comes with screen backing material to reinforce the break. Apply epoxy to the broken edges to glue the break together, then sandwich the screen on the back side with epoxy. Once cured, sand the front of the break level and spray on SEM texture paint or Rustoleum textured plastic paint.
But that's just me...
-don
blitz928
blitz928's Avatar
Buy a cheap rubber floor mat from Wal-mart and cut out a new one using the old one as a template.
Old 05-03-2010, 08:16 PM
syoo8
syoo8's Avatar
Very cool, MBMB. I respect that.
Old 05-03-2010, 11:14 PM
Shark Attack
Shark Attack's Avatar
bubblegum or duct tape....
Dude. just get a new one or a used one. They have to be a dime a dozen at the 928 yard. Look at a new one first. One time those used parts guys tried to bill me $30 for a part that cost $6 new at the dealer.
Old 05-03-2010, 11:18 PM
tailpipe
tailpipe's Avatar
make a new one from aluminum and have it anodized black way cool
Old 05-03-2010, 11:47 PM
Erik N
Been selling Twinkies on Ebay,
have some extra cash right now.
Erik N's Avatar
Tool up for a carbon-fiber replacement and everyone will want one. "Saves weight, etc. etc..."
Quick Reply: How would you repair this?
