Cam tower removal
The car is now up and running, and the cam tower job has been a success! I also installed a new intermediate idle control valve piece, as the other was cracked on the base. What is the ideal idle rpm setting for the 83 4.7l? I am sorry i did not post pictures of the sleeve inserts i used on the top cam tower bolt installation Checkmate, but honestly, i used some spiral cover and it looked like assembly lube covered garbage. Given better resources I'm sure y'all can figure out a nicer way. Although I could twist the paper material and make it grab the bolt so i could pull it out, which happened twice. Have fun with it^^ . Engine Sounds amazing
BIG THANKS TO THIS SITE/THREAD, THIS PLACE HAS SAVED ME NUMEROUS TIMES, THANK YOU............
