Fiberglass dash and console: First group finished, come and get them !
#46
Finall got a chance to throw it on the scale. It weighs 8 pounds. I no longer have a loose dash and console that I can weigh in comparison (I used them to make this mold), does anyone know the weight of the originals?
I'm very happy with overall result and weight.
#48
Administrator - "Tyson"
WOW, How did I miss this thread???? Beautiful work!!!
For a track car you don't even need a pod. Just a removable panel to install gauges or a more modern digital screen.
I am very interested for my track car.
#49
Ok I wonder how you made your mold? Did you manage to mould it in a one piece or is it a construction of different parts?
It seems that the external part of the FG dash board has been filling with polyester filler? Is that right?
I am in doing a dash board for my track project, but I decided to do it as simple as possible. I will not do it with the original look. I pursue 2 goal, weight under 2,5 pounds and less than 2 minutes to remove from the car.
Puyi
Puyi
#50
Puyi
Puyi
Once the mold it complete, the original plug is discarded and the glass materials are applied to the inside of the mold to create an actual part. You can make the mold as sturdy or as flimsy as you want. It depends on how many time you plan to use it.
This mold would proably be fine for a couple dozen parts.
#52
Awesome stuff, Dave--I can tell you are a perfectionist! Just out of curiosity, if someone created a plug, how much would your guy charge to make a mold and subsequent parts? You can PM me/email me at mark@theninesource.com if preferred. I realize it varies, but for something on a similar scale to what you did. I was thinking along the lines of a track-oriented front bumper and fenders, but who knows if I would ever have the time to get around to something like that.
Weights:
Dash - 12.6lb
Pod - 3.4lb
Console - 3.5lb (empty)
Weights:
Dash - 12.6lb
Pod - 3.4lb
#53
A fiberglass nose would also give you a solid place to mount the OEM lights without the front cross brace.
Yes, some of us still have lights in our track cars
#54
Weights:
Dash - 12.6lb
Pod - 3.4lb
Weights:
Dash - 12.6lb
Pod - 3.4lb
The price for doing this stuff can vary greatly. Most of the work is in the plug, but the plug also must be designed with enough taper or "draft" so that part will release from it after curing. When this can't be accomplished, the mold has to be made in mating sections and the price goes up.
As for glass front race flares.....sit tight, I have started on them already. I have a set of Ott rear flares and I want something similar for the front.
Most important note
![order](https://rennlist.com/forums/graemlins/order.gif)
thanks
tass
#57
#58
Unfortunatly, the fender sections of his front end are stock, not flared so it seems there would be no advantage in getting only fender side sections.
#59
I'm going to have one more dash made for my own use and then I'm moving on to other projects. I'm going to leave my mold with Walter ( the glass guy) for a while and he has agreed to do a run of dashes for $400.00 each (shipping will need to be covered by the buyers). This will be a onetime group-buy at this price. It might be a long time before a large enough group steps up again. Five dashes have been spoken for so far.
If anybody would like to get in on this, please send me a PM or an email and I'll pass it along to Walter.
thanks
Tass
thanks
Tass
