GT Unable To Idle And Very Rough Running
#106
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
What if that is the case? Maybe it's a mystery thing with the EZK and/or CPS? It couldn't hurt to get a new crankshaft position sensor and use another EZK.
#107
I'd have a hard time imagining a missing tooth spontaneously regenerating, but a pin could have fallen out....
#108
It seems very strange how the sine waveform Stuart measures is OK, but no sign of the gap...
#109
I will re do the CPS test again to be sure
Looking at page D28-11 in the WSM , the EZK plug pin holes facing, wires coming in from the left MY90 pin 18 lower and pin 35 upper is the start from the left, is this correct as i want to make sure i have correct way round of reading pin numbers
23+ and 6- are the ones i will be testing
#110
That's correct..... #6 is the ground. (-ve).
There are 60 teeth positions on the flywheel. 58 teeth and a gap of two teeth. At a cranking speed of ca 60rpm, you should get one big pulse every second. And of course "sine pulses" every 10th of a second.
#111
I took this short video of the CPS sine wave, sorry about the poor quality
http://www.youtube.com/watch?v=Ie-uZ1eJ6Io
#112
The CPS may be OK..... if it registers all the teeth then it can hardly fail to register the gap. You could get Adrian Clark to test your EZK in one of his cars.
#113
Its alive and running, i've put in another EZK ECU and it fired right up ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Thank you to everyone who helped and posted
Now i can strip out the trim, clean off glue etc and get it ready for a roll cage and recaro profi XL seats
#118
Guys
It sure is an odd failure, i did enjoy all the tests i carried out and the WSM is a must for everyone who has one of these great cars, i will say putting the key into the ignition wasnt a nice feeling of will it go or wont it
And once again thank you to everyone who posted help and advice
