GT Unable To Idle And Very Rough Running
#46
I would send your LH and Maf to John Speake or borrow someones. My car acted the same way. Sometimes wouldnt start at all. (no reference at the injectors, I think) Occasionally would run ok then after about a mile would revert to super rich. but most times it only just started and idled as though only half the pots were working and with a WW2 destroyer smoke screen out the back. Changed temp and air sensor, plus all relevant relays, changed leads, plugs & rotor caps, had all relevant joints on back of control board re soldered even had the ECU checked locally but it apparently checked out ok. After 2 weeks of both me and the porsche specialist trying everything sent the LH & Maf to John. He found an unusual intermittent spike in the ECU. Anyway sent me a new one and everything has been fine since!
That is apart from having a couple of noisy lifters caused by running it too rich when it first happened.
#47
Supercharged
I was going through some old emails and I recall another guy with a GT here in the US with a similar problem. Super rich all the time, couldn't rev it beyond a certain amount. Had a newly rebuilt MAF, LH, etc.
Turned out his new MAF was bad. Put in a BRAND NEW MAF and all was fine. Just a thoguht. If you have access to a known good MAF, you might want to try that.
#50
Another Update
Guys
I took both my MAF & LH ECU to JDS
John found my MAF to be shot , next up my LH was checked and found to be ok
So with a new MAF thank you John i set about getting the car running, but nope it wont fire at all, i have checked for a spark today again and just get small puffs of smoke but no spark from the plug, so i have no or an intermitant spark fault
#51
Supercharged
No spark could be a number of things. The first hign comes to mind is the Crank Position sensor. This is the sensor atop the bell hosing. Since you were just in there, maybe you dislodged it. If you take the air filter housing off, you will see the sensor on the bellhousing with it's cable snaking up toward the pulleys for the throttle cable. The connector, if memory serves, is located between the two pulleys.
If that's in place, these are some of the other things to check:
EZK - plugged in?
coils,
coil wires
final stage ignition modules
caps
rotors
EZK - plugged in?
coils,
coil wires
caps
rotors
#53
Here's a location picture of the CPS and connection under the pull (US car) - note the broken plug from the CPS:
#55
MMMMMMMMMMMMMMMMm boddingtons
I'll check the CPS in the morning, maybe i have upset it, it was new not that long ago
Doc, what are your thoughts on the ignition switch
#56
Another Update
Today i checked the CPS out
I followed the instruction in the workshop manual (D28-11) and checked the CPS sine wave pattern
This is what i got, sorry about the poor quality
Manual states 3V
Mine 2.24V
So is my CPS shot
Manual states 3V
Mine 2.24V
So is my CPS shot
