Cleaning Grounds
Thanks a lot for all your wonderful inputs ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
And thanks to "syoo8" for the pictures. It's fantastic what a picture can do!
Please continue posting pictures![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Please confirm this !! Is it correct understood that there is only two GP's that only can be accessed from under the car ?? The GP VII + IX !!
By the way syoo8 !! what were your "mission" in Denmark, Odense ??? If I may ask![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
I conduct the Odense Symphony from time to
time.
I just spray everything with a diaelectric silicone lube like WD40. It protects without trapping too much dirt. Worked like a champ on my 14 pin connector and my other grounds. Quick and easy using the red extension spray tube. I also spray just about everything rubber to keep it from drying out.
On my 82 I don't see a good way to get to the ones on the front right near the headlight arm, looks like it would be m2 in the first drawing. Anyone have a good idea as to the best way to reach them without tearing the front of the car off?
Thanks-Mike
Thanks-Mike
I have my car apart so no problem to get to for me, but I tried to get to that one on a friends car and it's impossible to access without removing things. I'd like to be enlightened if anyone has any tricks for getting to that one ... cursing didn't help as it usually does.
