Aero Hood Modification (Before i cut)
I made the splitter cut out today. what a pain, but I think when Im done, it will be a great template for a easy splitter mod to the S4 air dam.
Ok, here are the exact measurements:
24" up from the front of the hood, is the base of the trapazoid. the top side of the trapazoid is 29.25" from the front of the hood. the side closest to the front of the hood has edges 10" from the side of the hood. they angle up and get wider obviously, and end up 5.5" from the side edge of the hood.
(the size of the trapazoid that results from the above measurements is 24" top, x 7" side, x 15, bottom)
Here is the splitter design. one thing not shown there is that the air that spills over the edge of the splitter, or is below, still gets caught by the stock air dam lower scoop(which is still exposed under the splitter) and gets routed to the radiator and then out the hood vent.
