Probably a dumb question, but I don't have a lot of expierence with timing lights. I checked the timing at 3000 rpm, as per the WSM, and the timing mark was where the red line is in the picture. Now, it call's for 23 degrees BTDC, but the picture shows right at 28 (if that is a 28). Should the timing mark be right befor the 28 or right on it as the picture shows? And just out of curiosity, is "O/T" TDC?
The reason I even decided to check timing, is every third (or so) time i stop at a light or for some other reason, the engine starts surging. Almost like it is going to die, but doesn't. The idle just seems low. Once I give it a little gas, or put it nuetral, it act's fine.
Look carefully at the crankshaft dampener on your car, and see if it says 23 or 28 - I think that it will say 23.
Yes, 0|T is Top Dead Center (TDC) on #1 and #6 pistons. Remember that the piston comes to TDC twice in each cycle - TDC-Firing and TDC-Exhaust. The spark happens Before Top Dead Center Firing, not before Top Dead Center Exhaust. Likewise, the cam timing is based upon TDC-Firing, not TDC-Exhaust. The common way of showing ignition timing is degrees BTDC, with the assumption that you know that it is before the firing position, not the exhaust position.
You don't have to worry about that while using a timing light - just follow the manual instructions.
Thanks Wally, great stuff. Actually it says 20 on the crankshaft dampener. I was looking at the wrong page in the WSM. What was pictured was for a '78 (I think). Evidently my WSM has a mix of several years. flipping a few more pages, I found the correct one for the '83. It matches the sticker on the inside of the hood which says 20 drgrees BTDC. Is it still worth adjusting for the amount it is off?
I'd leave it where it's at--but that's just me. Quite a few with OBs advance the timing a little bit. Coincidently, your mark is almost exactly where I have mine marked on my 84 (assuming that would be your 20 degree mark). You can always adjust yours back to 20 and take it for a test drive and see what you think. Have fun with it!
From my experience, 34 - 38 degrees all-in at max RPM seems to be the norm for high-performance V-8 engines.
I agree.....but why is the USA 4.7L set SO low.....28' at 5000...when the others are 36'...... the only thing I can think of is it is the highest compression non Euro S motor...at 9.3..maybe they went super conservative for emission reasons?
I need to do some dyno tuning on the lemons racer to see if it responds to more timing.....
