Rear main seal installation help
Captain Obvious
Super User
Super User
When replacing the rear main seal on an S4. Does the front of the new seal has to be flush with the engine block or will it go in until it bottoms out? Looking at the workshop manual, looks looks like there is a machined step that the back of the seal will bottom out to but this leaves the new seal around 1.5-2mm passed being flush with the face of the block. The old seal looked flush when it was removed.
I may be doing this on my OB before long.
Rest in Peace
If the crank does not have a grove worn into in where the old seal rode, install it to full depth with the installation tool.
Many factory tools have a spacer that is to be used in places where you need to have the new seal ride on a area that is not worn.
The 928 cranks seem to be very hard and do not suffer from seal wear and no spacer is supplied with the tool.
I recommend using the factory installation tool, not a piece of PVC pipe.
A lot of folks have bought the tools for installing seals, so you should be able to borrow what you need, or call your 928 parts person and buy your own.
Never, ever, hit a seal with a hammer directly on the seal, even to "Just start it".
Captain Obvious
Super User
Super User
The old seal looked original from '89 and was flush with the block. It was in there tight so I don't think it migrated over time, but you never know. It could have when the engine was warm and the block expanded.
If the factory setup is to have the seal bottom out, then I'll drive it in untill it does.
just performed this yesterday. i installed flush to the crankcase and called it good. cleaned the crank and there was no grooves or wear spots . i don't think the idea is to drive the seal till it bottoms out
Captain Obvious
Super User
Super User
there is more "room" in the crankcase for the main seal than what is needed. if you installed the seal flush with the crankcase but the sealing lip ended up on a less than perfect surface of the crank than you should drive it in more, to a better part of the crankshaft. as someone noted these cranks wear really well. i think it's more important to keep the rear main seal perpindicular to the crankshaft. keep the seal lined up evenly all the way around the crank so the spring has equal tension all the way around
RIP
Having just done this twice I know that you drive it in until it is in past flush ! The first time it was flush and it still leaked , had to go back in and knock it in some more that sucked.
Supercharged
I was there with Dennis on this. The problem with leavin it flush is that it will leak at the cutout on the block (presumably the cutout is there to dig out the old seal). When the seal is flush, the rubber portion of the seal barely touches the cutout. Needs to be 1-2mm past flush to properly seal.
Captain Obvious
Super User
Super User
And yes, the cut out is only there to remove the seal. It's a nice touch by Porsche as all the other engines I've worked on didn't have this and removing a rear main seal was a little more difficult.
Rest in Peace
You may get lucky and not have the seal leak, using a old seal to kind of dampen the hammer blows really is not going to do much, plus what are the chances of it being in straight?
If it is crooked it will not give you the service it should or just leak out right.
When I said drive it in until it bottoms out, I was talking about using the factory seal tool, it has a lip that puts it in the right spot and SQUARE.
I was not saying drive the seal in with what ever you had laying around until the seal would go no more.
That old saying, "Use the right tool for the job" may just apply here.
I've used the old seal as a driver so the new one never received a single hit from a hammer. However I was expecting the new seal to bottom out at some point (like it does on every other kind of engine I've ever did this on), but it just kept of going and this supprised me a bit. It's about 1.5mm passed the face of the block now and haven't yet bottomed out. It should very soon but before it does, I want to ask others, with first hand experience, what their take is on this.
Supercharged
BTW, I've done this job twice now and it still leaks. I'm certain I only drove the seal flush - becasue I didn't know better. Yes, the right tool would have probably cured this, but alas I didn't have it. So I've been living with a leaky/seapy RMS for about 2 years. Looking for a good excuse to drop the clutch and flywheel.
Rest in Peace
I tried this once before, but we need to put together a list of who has what factory tools that they would be willing to lend to persons that are in need.
I mean even as a pro, how often am I going to need a rear main tool or any of the others?
You can get stuff shipped overnight pretty much any place in the 48 states.
Just a thought.
Just a thought.
Captain Obvious
Super User
Super User
My question was the pros and cons of having the seal being flush or recessed against the back of the machined step of the block.
