Steering Rack Bushing Removal
Lizard, thanks for the heads up!
Oh, when I ordered the bushings, they showed up the next day - excellent service.
Team Owner
I use an air chisel with slightly curved blade to push the swages into the center,
then a bit more hammering into the center of the bushing and they pop right out, go easy so you dont twist the rack.
it takes about 2 minutes per bushing to remove them
Some Emory cloth will clean out the corrosion on the bushing bores
