928 Engine Question?
You guys are funny.
Actually, there is ozone created from the spark jumping from the rotors to the caps. Without the intake system drawing off this, the timing belt would deteriorate at a much, much faster rate, as rubber and ozone are not friends.
The 944 models used a plastic cover that kept the ozone out.
Mrmerlin's idea is interesting but the engine already has a cam belt failure warning system. All that hot air drawn into the cold air intake is a high price to pay for warning about something that is already been warned about?
It can't possibly make much difference, really. I run the cars with the vents connected, not connected, tubes on the car, tubes off the car. No difference.
It's the cause of the 2-6 bearing failure problem.
The air drawn in through the TB covers cools the TB pulley region of the crankshaft causing the front of the crank to run at a cooler temperature. This causes a thermally induced relative vacuum in the crank oil passageways at the front which draws in more aerated oil to the 2-6 bearing area
Simples
innit
Simples
innit
Thanks for your answers.
I think I agree with the whole removing of oil vapor, ozone and generally bad things for the belt idea with negligible effect on cold air intake.
Basic Site Sponsor
Basic Site Sponsor
I like your theory as it's similar to what I heard. But the only problem with it is the original 928 engines up to the S2 engine did not have distributors mounted on the ends of the Cams but they still had the vent holes?
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
thats why amzoil is used to reduce cam timing belt stretch and wear. the 10buck a quart oil has vapors that coat the timing belt, making it impervious to ozone, oxygen and also fights issues when running dry tensioner housings.
Intake on the passenger side induces a coriolis effect similar to the Atlantic (CW) while the driver’s side has a Pacific coriolis (CCW) effect thus creating geostrophic forces (aka Eötvös effect) in the middle of the engine. The ribbed belt forces oxygen molecules closer together and super saturate the inbound air for high combustion.
Inventor
Timing belt cooling.
The intake is next to the crankshaft, behind the oil level sensor.
I thought they were there as an air pressure relief. When the car is driven at 928 speed, the intake tubes can scoop up too much air, throwing off A/F mixture.
You guys are so dumb... clearly the holes at the top of the TB covers are the access point for water to be poured into the covers so that the volume of the interior area can be measured. The more the TB wares the greater the interior volume of the TB cover system... you then measure the volumetric difference over time and tells you that you need to change the belt. Your welcome, next time I'm going to charge for that knowledge.
