Just an FYI - Degree wheels -
I have to thank Greg Brown for helping me wrap my *English Major* head around the numbers that are required for timing cams. Its still a work in progress, and I have no finished, but I thought I should mention it.
Secondly, he always mentioned getting a 180 degree timing card/wheel so I can simply look at it to "see" it in my head as to what I was doing. I did not get on, and I really wanted to attempt the process this weekend. So I searched around and found one that should work quite well, that was free, and can be printed on your home printer
http://img20.echo.cx/img20/4583/degreewheel9dg.jpg
If you adjust the size you are printing at your printer preferences, you can print it out to nearly the entire size of your paper. Using photo paper makes it more clear, as well as stiffer so you may not have to put backing on it.
Brendan, keep in mind that if you miss getting the hole dead-on center by even the width if one line, its going to be inaccurate. Engine shops go to extremes to insure that this wheel is perfectly centered on the crank before timing cams. I don't mean to burn your toast- just be aware of the concentricity requirement... ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Steve
Steve
Yes. I didn't have toast, though, so don't worry. I didn't even have breakfast - went straight to the garage in my pajamas.
I checked it against the stock dampener. The reason I even am here is because I felt the ATI dampener may have been a bit off from when I was trying to find True TDC. The stock dampener was more accurate, but I needed real numbers (180+180) to do the math the way Greg taught me. The ATI dampener has 360 degrees, which confuses my mind a bit, and the stock one only has a few marks.
So this was my solution. Concentric-wise seems to be okay.
Rest in Peace
I can not remember which one I used for "Avatar Day", I hope this one works for you.
You just know that some one is going to have a issue with it though.
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Former Sponsor
That right there, that's a big degree wheel. Mine is about 8 inches in diameter. If I had to do this alot, I'd get a big one as well, so you don't have to eyeball it. Even better, some sort of digital counter on the pointer pin so you can just turn it and look at a big digital screen.
I now have the engine so both intakes are about 122 or so center lobe. The Cams are S3, so that's about 1.5 retarded, from my training. I was going to go for 3 retarded, but I will probably set here and go forward with the build. The software showed the best power at 3 degrees retarded, but The real world may be different.
3° retarded from split overlap or 3° retarded from Porsche's timing?
Porsche settings for S3 cams are already 6.5° retarded (intake at 120.5°, lobe separation of 114°). W/ the intake cam at 122° ATDC, the cams are 1.5° retarded from the factory setting, 8° total.
