928 Forum 1978-1995
Sponsored by: 928 Specialists
PET 7.1 Anyone using this ????
Old Mar 12, 2010 | 11:11 AM
  #31
Vilhuer's Avatar
Vilhuer
Does setup try to install program parts under 64 or 32 bit part of the windows 7 folder structure? Could be that it just tries to get to wrong area by default and needs to be pointed towards 32 bit folders.
Old Mar 12, 2010 | 11:13 AM
  #32
blitz928's Avatar
blitz928
Originally Posted by KenRudd
+1 to Matts result.
Error translates ( per Google) to:
"Information about the existing dongle dll version: 1.61 The response of the hardlock error occurred 7 to"
I've tried Troubleshooting compatibility, I've tried to back date service packs for XP which was recommended and still no dice. THe error is "incompatible application" if you go through the troubleshoot guide for windows 7
Old Mar 12, 2010 | 11:19 AM
  #33
dprantl's Avatar
dprantl
I had this happen on my 32-bit Windows XP install. It stopped when I opened a command prompt, changed the dir to \PET\prog and ran pet7.exe. Either that or attempting to run it a certain amount of times made it go away.
Dan
'91 928GT S/C 475hp/460lb.ft
Old Mar 12, 2010 | 11:27 AM
  #34
WallyP's Avatar
WallyP
Rennlist Site Sponsor
If you get into playing with 32-bit vs 64-bit folders, do some research first - they are NOT what you expect!
Old Mar 12, 2010 | 12:11 PM
  #35
Tom. M's Avatar
Tom. M
Deleted
Ok..just double checked my install and it seems I found v7.0 update 226/28 . So not the latest 7.1 but it works and i was just able to update prices and seems to work flawlessly on my Win 7 64bit machine. It's not like the 928 parts are changing anytime soon..so I'll likely stick with this version. BTW..the VIN search is pretty cool
I tried downloading DR's linked files, but can't get those file servers to work consistently.
Anyway...found mine via google search and it linked me to a site "megaupload" where the version was...
Old Mar 12, 2010 | 12:36 PM
  #36
rluvsporsche's Avatar
rluvsporsche
DR, Thank you.. See in June
Old Mar 12, 2010 | 01:37 PM
  #37
F451's Avatar
F451
Just installed 7.1 on my Win7, 32 bit machine.
Works great! Thanks for the info DR!
Old Mar 12, 2010 | 07:35 PM
  #38
blitz928's Avatar
blitz928
I installed the PET 7.0 and it works great, thanks Dave.
Old Mar 12, 2010 | 07:44 PM
  #39
watchcam's Avatar
watchcam
Thank you, very useful!
Old Mar 13, 2010 | 03:00 AM
  #40
6mil928's Avatar
6mil928
From: No where Oklahoma AKA "The Dust Bowl" In The Arm pit Of Hell
Just loaded PET 7.1 what an excellent program. Thank you so much. It won't update it says access denied. Great program anyways.
Old Mar 13, 2010 | 08:00 AM
  #41
M. Requin's Avatar
M. Requin
Thanks DR, very useful addition to my docs.
Old Mar 13, 2010 | 11:54 AM
  #42
R.Pires's Avatar
R.Pires
Hi,
Downloaded, installed and working perfectly in my “old” XP!
Thanks to DR for the very well explained instructions!
Regards
Old Mar 14, 2010 | 01:34 AM
  #43
SharkSkin's Avatar
SharkSkin
I'm having a strange problem following DR's install instructions; when I try to install the updates I get an error that says something about "access denied" to C:\PET\DATA\PO\update\temp. I downloaded from the first set of links.
Anyone else having this problem with XP SP3?
Old Mar 14, 2010 | 01:46 AM
  #44
SeanR's Avatar
SeanR
I didn't, but I used the CD version.
Old Mar 14, 2010 | 04:26 AM
  #45
figgen's Avatar
figgen
Great link - Thanks , installed just fine
I really like the feature to put your VIN number in and it highlights the appropriate parts!
Much better interface than the previous versions
