928 Forum 1978-1995
Sponsored by: 928 Specialists
Lifting a 928 ENGINE
Old Jan 28, 2010 | 10:51 PM
depami's Avatar
depami
Default Lifting a 928 ENGINE
Here’s a simple question.
Where does everyone put the floor jack to keep the pads clear for jack stands?
Here is another simple question:
I am preparing to replace motor mounts. I realize that I can lift the engine from the bottom, but, I am going to replace the pan gasket as well. Where is the best place to “grab” the engine from the top?
I can not find any lifting points on the front of the engine. This is on the 86.5.
Old Jan 28, 2010 | 11:08 PM
fraggle's Avatar
fraggle
I lift the front first, using the lowr control arm mount bits.
Once the front is high enough, I put the jackstands in. Then go to the back and lift!
Front of the engine can be lifted from a lift point attached to one of the heads.
Old Jan 28, 2010 | 11:31 PM
Jerry Feather's Avatar
Jerry Feather
I think there is a lifting point bolted to the front of the water pump. There is also an extensive thread about how to do this recently on this forum, I think. It shows how to lift the engine from below then use a harbor freight engine lift bar across above the engine to hold it up where you need it.
Old Jan 29, 2010 | 12:43 AM
Lizard928's Avatar
Lizard928
The 85/86 cars dont have the lifting lug at the front of the engine.
Use a strap and wrap it around the fan housing at the base where it bolts to the WP. Lift it there.
Old Jan 29, 2010 | 08:06 AM
Bertrand Daoust's Avatar
Bertrand Daoust
I don't know it would work on 85/86 but you can use this thread to build you something to ''hold'' the engine from above.
https://rennlist.com/forums/928-foru...-question.html
Thanks to Andrew Olson for this.
It did work very well for me.
Good luck.
Old Jan 29, 2010 | 11:02 AM
Jerry Feather
The Harbor Freight ENGINE SUPPORT BAR shown in one of the other very recent threads will work very well however you hook it to the front of the engine. I bought one for 49.99 when it was on sale from about 59.99. I suppose two of them could take the place of the double 4 by 4 method of you are interested in twice the money, but fewer trips to the lumber yard and less carpentry.
Old Jan 29, 2010 | 11:09 AM
Don Carter's Avatar
Don Carter
The front engine lift point on 85/86 is on the passenger side of the engine near the front, but not on the front of the engine. It's a rather thin looking peice of metal with a hole in it. Took me a few RL searches to find it too.
Old Jan 29, 2010 | 11:13 AM
antsmands's Avatar
antsmands
Look at Dwayne's write up on motor mount replacement. He has details on building the 4x4 hoist.
7 Porsche Models That Have Aged Like Fine Wine
Old Jan 29, 2010 | 11:21 AM
dprantl's Avatar
dprantl
Don't you have to disconnect the front driveshaft coupler before you try lifting the engine for such a job? Or do you have to drop the whole clutch pack?
EDIT: Nevermind, the whole engine/torque tube/transmission unit should tilt up during engine lifting.
Dan
'91 928GT S/C 475hp/460lb.ft
Old Jan 29, 2010 | 11:40 AM
Jerry Feather
I pulled the last thread about this up front for you. I hope it helps.
Old Jan 30, 2010 | 12:02 PM
depami's Avatar
depami
Thanks for all the suggestions, guys.
But my point is: there are no lifting points on my engine!
Where should I attach a lift cable?
Can I use a strap around the crank shaft?
Old Jan 30, 2010 | 12:04 PM
dprantl's Avatar
dprantl
Someone mentioned using a strap around the fan clutch support in another thread.
Dan
Old Jan 30, 2010 | 12:15 PM
depami's Avatar
depami
Dan
I considered that but it bothers me. Looking at that part and the way it is bolted on; I don't think the geometry indicaates a good lifting point.
Old Jan 30, 2010 | 12:56 PM
Landseer's Avatar
Landseer
I just loop around the fan housing also on the 85 and 86. I stay very close to the block. It works.
You could pull it off completely and bolt a bracket at the same location instead, like the 87 cars have tucked under there.
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
