928 Forum 1978-1995
Sponsored by: 928 Specialists
Odometer
Old Jan 18, 2010 | 04:48 PM
RED928's Avatar
RED928
Default Odometer
Just replaced the gear in the speedometer assembly. Everything seemed to go back together correctly and the gears meshed well before putting the dash/pod back together. However... odometer is still not working. What should I look at next?
Thanks,
Steve
88 S4 Auto
Old Jan 18, 2010 | 08:39 PM
billtool's Avatar
billtool
I wanna know as well. I'm doing that job this week-end. Need to head the issue off at the pass...
Old Jan 18, 2010 | 09:03 PM
Lizard928's Avatar
Lizard928
Open it back up and there is the small motor with the worm gear on it. If that motor fails then the odometer will stop working.
I also experianced a new failure for the speedo/Odo the other day. I had a resistor burn up so to speak on the little board on the back of the speedo. Thankfully I had another slightly damaged speedo that I was able to steal it off of and I just unsoldered the two wires for the speedo and soldered them into the new board.
As well on the PCB on the back of the cluster there are 4 pins which transfer the signals to the speedo. They then have rivets beside them. I always take small jumper wires and solder from the back of the pin to the jumper, and then onto the pcb. This ensures that the fix will last. And that the speedo will work right from the start.
Old Jan 18, 2010 | 11:41 PM
ROG100's Avatar
ROG100
Basic Sponsor
I have done a lot of these and in the begining this happened after I had replaced the pod - GRRRR.
Often the small parts of the disintegrated gear get lodged in the existing gear mesh.
Blow out with compressed air and make sure no bits are left.
If that does not make a difference refer to the above post from Lizard.
Old Jan 20, 2010 | 07:44 AM
RED928's Avatar
RED928
Thanks... what's the best way to check the worm gear motor?
Steve
Old Jan 20, 2010 | 10:53 AM
Ian S4's Avatar
Ian S4
Steve
The odometer and speedo are driven by an integrated-circuit, UAF2115, "Speedometer and Mileage Indicator", made by ITT.
The odometer motor is driven by pins 2 and 12 of this IC. When the rear wheels are turning, you should see pulses on both of these pins. If you see the pulses but the motor does not move, then the motor is busted, or jammed. If you don't see the pulses, then the IC is likely fried, or the windings are open circuit.
This test is much easier to perform if the speedometer is removed from the car, and an external signal is used to fake the signal from the sender on the differential unit.
Old Jan 20, 2010 | 11:50 AM
Brett Jenkins's Avatar
Brett Jenkins
When I replaced my gear, it quit working fairly quickly, so I shimmed in a few thin washers so there wasn't any 'slop' in the entire gear assembly. It has worked flawlessly ever since.
Old Oct 18, 2012 | 12:30 AM
william_b_noble's Avatar
william_b_noble
the chip is available from odometergears.com for $25 - anyone found it for the $5 it ought to be? I found it in 10,000 quantity, that's not what I want.
