928 Forum 1978-1995
Sponsored by: 928 Specialists
2011 New Mustang 5.0 vs. 928s4/gt
Old 01-05-2010, 01:26 PM
JCP1990S4
JCP1990S4's Avatar
Default 2011 New Mustang 5.0 vs. 928s4/gt
I noticed that the 2008 Mustang GT has similar performance specs to our cars. But it was pushed out of the 4.6 V8.
Now the new 5.0 even looks like our late model motors especially the first 86. Displacement almost identical.
my 1990 928
5 litre
4957 cc
(302.495 cu in)
2011 Mustang
5 litre
4951 cc.
(302 cu in)
Mustang pushing 100 more ponies!!
http://autos.aol.com/article/2011-ford-mustang-gt
Old 01-05-2010, 01:35 PM
Iwanna928
Iwanna928's Avatar
Sweet motor! She would be fun to drve!
Stephen
But I would rather have a 928!
Old 01-05-2010, 01:45 PM
docmirror
Shameful Thread Killer
docmirror's Avatar
The variable valve timing is the key to power and economy. Driving around at 1/4 throttle most of the time keeps the cam lobes very narrow. I'm pretty sure the duration is also altered when you put your foot down releasing the power.
GM took another approach with displacement on demand, by deactivating cylinders in economy mode.
Old 01-05-2010, 01:46 PM
Richter12x2
Richter12x2's Avatar
Chrysler does that too, on the Charger V8's especially, shutting down half the engine and running on 4 cylinders for cruising.
Old 01-05-2010, 04:07 PM
porsche 928 RI
porsche 928 RI's Avatar
too bad it will take ford about ten years to get the thing reliable..
Old 01-05-2010, 09:46 PM
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
Not just variable valve timing but even vast improvements in EFI also makes this happen. Refer to Megasquirt, Electromotive, etc 928s.
Old 01-05-2010, 10:28 PM
IcemanG17
IcemanG17's Avatar
totally different engines.....the 928 is a "big block" with a short deck.....the 4.6 family Ford engines are a small block and shorter deck.....the 928 is a 122mm bore spacing with a 232mm deck...the 4.6L ford is 100mm bore with 227mm deck....the 5.4L retains the 100mm bore but with a taller 254mm deck required to make the displacement
How the 5.0L mustang engine makes its power its through its 11.0-1 CR and variable cam timing....that with modern engine controls allows for much more aggressive timing-fueling....
For reference....my 4.0L V8 in my M3 makes 414whp (closer to 450)..or 3 more than the 5.0L in the mustang..with 20% less displacement...
The 5.0 L (4951 cc, 302 cid)[9] "Coyote" V8 is the latest evolution of the Modular engine. It retains the 4.6 L's 100 mm (3.937 in) bore spacing and 227 mm (8.937 in) deck height while bore diameter and stroke have increased to 92.2mm (3.629 in) and 92.7mm (3.650 in), respectively. Compression ratio is 11.0:1, despite having typical port fuel injection (as opposed to direct injection) the engine can still be run on 87 octane gasoline.
Old 01-05-2010, 10:59 PM
V2Rocket
Rainman
V2Rocket's Avatar
that is a nice looking engine, good output too. nice to see a serious performer mustang.
IT NEEDS AVAILABLE IRS
Old 01-05-2010, 11:00 PM
V2Rocket
Rainman
V2Rocket's Avatar
the supercharged version of this thing will be insane, even on just 91 pump!
Old 01-05-2010, 11:09 PM
goodspeed928
goodspeed928's Avatar
30 YEARS! I think it should have 550hp
Old 01-05-2010, 11:19 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,168 Likes on 1,225 Posts
So should every 928
Old 01-05-2010, 11:55 PM
Richter12x2
Cobras of each year typically get this.
Old 01-06-2010, 12:26 AM
cold_beer839
cold_beer839's Avatar
What makes you say that?
They seem to reliable enough to be out selling GM and Chrysler, and Obama couldn't jam the bail-out funds down their throats either.
Old 01-06-2010, 02:01 PM
porsche 928 RI
my buddies 01 cobra cam chains went at 31k, head gasket at 35k, and then two weeks later snapped a rod.... the thing was bone stock never beet on
Old 01-06-2010, 04:37 PM
dprantl
dprantl's Avatar
I can second the craptastic quality of early 2000 mustangs. One of my coworkers owned one and was modifying it for more boost. At something like 400rwhp, one of the half-shafts snapped.
Dan
'91 928GT S/C 475hp/460lb.ft
Quick Reply: 2011 New Mustang 5.0 vs. 928s4/gt
