Working on Fuel Dampers - Front Fuel Line #928.110.269.01 Crumbled!
Received 1,603 Likes
Also, to prevent problems further down the line....
for the vacuum system connected to the fuel pressure regulator and dampeners: replace every rubber elbow, the vacuum lines, and the 5-way splitter. The fuel turns the rubber to jelly in short order.
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
I'm bumping this thread up again.
Got my parts ready to go for tomorrow, but completely forgot off the top of my head what size the mounting nut is on the fuel dampers? Is it a 21mm???
EDIT: For future reference the mounting nut on the front fuel damper is 23mm, NOT 21mm.
19mm on the line. 15mm on the damper to counterhold and Mounting at the base is 21mm IIRC
Team Owner
use some anti seize on the flare nut connections so they can be removed later.
dont overtighten the connections as they will deform the fittings
Fuse 24 Assassin
Fuse 24 Assassin
Thanks for the tip everyone. This sucker will be running this weekend. Pray to your 928 Gods for this shark's resurrection
Fuse 24 Assassin
Fuse 24 Assassin
Bump - I will finally get the chance to work on this car this weekend if it doesn't get rained out again.
I've got my fingers crossed that my stalling at idle when the car is warmed up goes away when the dampers are done. These 2 dampers are probably the only things left to do that have never been replaced in the car's 23 years of existence.
Be sure to keep us posted as to the results...having read this I've decided to replace all the dampers on my '85 when I do the intake R&R, injectors, etc in the coming weeks...
Fuse 24 Assassin
Fuse 24 Assassin
Sure thing. I'm going to work on it in another hour here. Nice and sunny today ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Blitz - I don't have a fuel pressure gauge to hook up. Looks like that's one thing I need to pick up for this car. I was thinking of one of those ones you can mount up to the passenger side fuel rail.
Fuse 24 Assassin
Fuse 24 Assassin
Doh! Fuel line 928 110 269 01 from the front passenger fuel rail to the front damper crumbled!
Anyone have a spare? I hear this one is a PITA to order. I knew sooner or later this one would give out..
I've got my fingers crossed hoping I don't need anymore lines. That horse shoe shaped on the back is new luckily. Anywho, no sense on doing any further work until I get a replacement line.
Administrator - "Tyson"
Just imagine if it would have failed while you were traveling 75mph down the highway.
You should replace ever piece of rubber that holds fuel under the hood.
