Cup 4's on an S4
Those wheels are called cup 4? I had no idea they were a porsche wheel honestly.
Same as on the GTS should work fine... GTS's have BIG spacers on the rear to push the wheels further out. You can take GTS wheels and put them on an S4 w/ no issues, so an aftermarket wheel will be the same...if it works on a GTS it will work on an S4... I think 19" are a bit big, but that is just me. Not to mention the rubber is just that much more expensive and the weight is higher and thus cut your effective wheel HP/Tq down a bit...
Perfect! Thanks. Bummer that there isn't a 17x10 et65... that's the wheel I'm really looking for. I'd like to limit my tire costs by running 17's on the track car while also running 10" up front under un-flared S4 front fenders (needs an et65 wheel I believe from my thread searches). I know there are 18" carrera wheels that are et65... but I can't find 17's... the search goes on.
Dan
'91 928GT S/C 475hp/460lb.ft
These look very good because to me they are a mix of one of the turbo twist designs with the Tech art wheel. I think 18's would be the best.
19's overpower the 928
https://rennlist.com/forums/6268453-post34.html
https://rennlist.com/forums/928-foru...ont-88-s4.html
As far as 18's... I don't need anything larger than a 17 to fit over my brakes. I have driven some incredibly fast track cars than were running 16's and the slight side wall flex of 17's vs 18's is not too much of a concern either. All 18's do for me is cost me more for the rubber. I'm sure I'll have to go that route... but a 17x10 would be perfect, better yet... a 17x10 Cup 2... that's the ticket.
