Intake manifold differences S4 vs GTS ?
I was powder coating intake manifolds yesterday and noticed some subtle differences between S4 manifold and GTS manifold and intake manifold side plates. Both side plates have the same part number. Does anyone know what the projection on the cover plate is for? Also bottom of GTS manifold vs bottom of S4. Does anyone know why the change?
This is an '89 S4 that still has that connector (and the exhaust-sampling tubes):
![Name: IMG_3320.jpg
Size: 103.5 KB](https://rennlist.com/forums/attachments/928-forum/402715d1259600964-intake-manifold-differences-s4-vs-gts-img_3320.jpg)
Probably not much help but ~7 years ago I had an insurance company replace the intake on my 89 GT b/c of a careless detailer and from what I remember the part numbers are the same for the GT and GTS.
Team Owner
the flappy picture is missing the eccentric flappy stop, this nut head with a hole drilled into it off center keeps the flappy plate from binding on the inside of the intake housing.
Dwayne also has this part pictured on his intake R n R thread , his was also missing.
Best to position the bolt head as best you can then tap it onto the roll pin, a drop of green loctite is good here. also be careful about twisting the head once its on the pin, the pin can shatter
Is there a part number for the missing eccentric flappy stop? It's not shown in PET. I don't recall ever seeing this part before, and now would be the time to replace it. .
https://rennlist.com/forums/6900259-post176.html
Hilton - I was completely unaware of this part. Cut off bolt head seems like a good common sense solution. Thanks for the information.
Stephen - PM sent
Stephen - PM sent
