Headlight adjuster arm..???
Can someone tell me, is the arm with the ball sockets on either end hiding behind the headlight - which is used for electronic height adjustment and which also stops the headlight shaking in the up position, available.
Mine has broken and i have a floppy headlight.
The plain plastic piece(non-adjusting) is called a "support" P/N 928.631.201.02 in PET. PET does not have a P/N for the electrical adjuster. Your description above should be plenty for any of the big 3 to get you the right part.
