928 Forum 1978-1995
Sponsored by: 928 Specialists
Bilstein assembly question
Old Oct 3, 2009 | 02:18 PM
LVPAVING's Avatar
LVPAVING
Default Bilstein assembly question
Can anyone tell me if this is the correct way to assemble Bilsteins? (minus the springs of course)
File Type: jpg
Old Oct 3, 2009 | 02:20 PM
Lizard928's Avatar
Lizard928
Yes that is the correct orientation of parts on the shock.
Old Oct 3, 2009 | 02:25 PM
GlenL's Avatar
GlenL
I think the three-ring foam piece goes on with the conical end up.
Old Oct 3, 2009 | 02:41 PM
LVPAVING's Avatar
LVPAVING
Great, Thanks for the input, I would hate to have to disassemble after getting them together.
Old Oct 3, 2009 | 02:51 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
The large washer to the left in your photo looks upside down (it should be convex up). The bump stop is correct (conical down). If there are grooved lines cut into the plastic washer that goes below the bump stop, the grooved side faces down. Grease the rubber on both sides of #3 below with a rubber-compatible (non-petroleum) grease. There are some bushing lubricants or synthetic greases, like SuperLube, that are good for this use.
File Type: jpg
