parts for S4 auto transmisson service ?
Hi,
what is needed to perform a service on the MB auto tranny on my '91 S4?
I have no time to order parts from the 928 vendors, so I was hoping to pick it up at the MB service counter.
thanks
thanks
The auto is a MB 722.3 four speed box.
You can obtain a "Service Kit" that basically containes a filter and pan gasket.
If you have a PET the part numbers are the MB part numbers,
Ensure that the pan gasket is the newer thicker gasket as the old original one used to split longitudionally.
Follow the WSM regarding fitting and torquing up the pan set bolts.
Tails 1990 928S4 Auto
Tails also posted an excellent pdf document...see post #19.
https://rennlist.com/forums/928-foru...ans-fluid.html
I changed the filter and gasket and it made a huge improvement. The car shifts smooth as silk now.
I only drained the tranny fluid and not the converter, so I will change the fluid again in a few days and drain both.
