Anybody have CE spare parts?
Does anybody have a spare 5 fuse section from an S4 CE panel, preferably in white? My fresh air blower fuse holder finally gave up week before last. After removing the CE panel and disassembling the offending fuse section (thanks to Alan and others excellent posts and pics on the subject
) I need to replace both plastic parts of the 16-20 fuse section and one single blade fuse connector. The supply side five blade buss is fine as are the other four single blade connectors. PM me if you can hook me up.
Mike
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Mike
Thanks Colin. I only need one section as the rest of the blade ends of the other fuse connectors look A-Ok without a trace of corrosion or discoloration due to heat.
PM with address inbound.
MIke
MIke
I need block 16-20. It is a nice thought that they put the numbers on the blocks, but until I read some posts here and then took my CE panel out, I did not even know the fuse positions were numbered. I just figured you had to refer to the chart and know how to count by five's.
Mike
Mike
Location: In the boatyard installing the mast and engine, we don't need a crane, we harness the mesquito's! Yeah!
1 Post
Hey now...
You buy a used car from me and don't ask me for parts?
Geeeze - give the man a forever gaurantee and they don't take ya up on it...
Whats wrong with the world these days!![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
I've got one Mike.
Try to call when I'm sober next time - will ya!![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
I've got one Mike.
The only way you would part out a five speed is if that was the only way for those parts to live again, and then it would be you parting one five speed to salvage another to add to your fleet.........
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Electron Wrangler
Just a note - these vary by year so check the actual connections.. Internal to the fuse holders the input side terminals can be bridged in different configurations (even for the correctly numbered blocks) I know this seems quite unintuitive - but true.
Alan
Alan
