The Panamara has the biggest front brakes I have ever seen! 20" wheels and the rotor completely fills it. The caliper has to be at least 12" long.
They are very large, I assume they use the same brakes as the Cayenne Turbo S, which a neighbor of mine owns, they are really huge as well, 6 piston fronts. No cross-drilled rotors on the Cayenne though which looks strange when you have a brake set-up that large. I know the cayenne turbo s requires 20" wheels just to clear the brakes.
This particular panamera has the PCCBs. Hence the yellow calipers.
